Results 1 to 7 of 7
Thread: can smell oil in the coolant resivoir
    vn
    Feb 2009
    Default can smell oil in the coolant resivoir
    hi guy
    can some 1 help me with this problem when i check the water in my vn i can smell oil in my coolant and is a dark and rusty color i have flushed it but sill comes back the rust and smell off oil has no blowing head gasket the mainafold is not leaking have had it pressor tested and is lossing pressor but we do not know where it is leaking from it dosent seem to be leaking from what i can see
    can someone help me please cheers
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    check under your oil cap, is it milky? if so could be the head gone, i would highly consider, unles you havent alredy, takeing the whole radiator out and high pressure washing it to make sure you got all the crap out of it.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    vn
    Feb 2009
    i have checked under the oil cap and dipstick there is no milky colour uner cap or dipstick this what i can not work out
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Could there be a possibility that you have transmission fluid leaking into your radiator? How old is the radiator??? The Transmission oil cooler pipes run through the radiator and may be leaking and collecting rust from the radiator along the way. Could mean its getting into your cooling system. I dont know, I may be wrong. Loss of compression is one of two things - Worn piston rings or worn valves. You could have two problems... ?
    vn
    Feb 2009
    it not blowing smoke the car seems to run strong but the radiator is old i have not lossed any transmission oil
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    It'll be the inlet manifold.The inlet manifolds corrode away coz they're made of alloy...
    Tony 308vkcalais:
    vn
    Feb 2009
    i have checked that and it dose not seem to leak but i have notice the oil needs to be toped up every 2 weeks i think the onley way is to pull the thing apart
  1. Smell of Coolant in cabin, heater core?
    By b1lly in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2008, 07:26 PM
  2. Coolant smell
    By ringfeder3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2008, 12:40 AM
  3. coolant smell??
    By clarkey3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 10:57 AM
  4. New car smell
    By ClairBear in forum General
    Last Post: 06-06-2006, 01:49 AM
  5. coolant smell
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2004, 12:48 PM
