Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: can i leave my air intake off????
    VP Exec S2 3.8
    Feb 2009
    Default can i leave my air intake off????
    I have a VP V6 series 2, i was fiddling around trying to remove the bellmouth but i didnt have a socket to reach one of the bolts. So out of curiosity, i took it for a run with the whole air intake system removed, so the throttle body open is exposed. The difference in instant throttle response was AMAZING, before there was a bit of a dead spot when you first apply the accelerator, now it's gone completely. It also idles smoother. Theres quite a noticile increase in perfomance aswell, and it makes a nice noise when you open it up, you can really hear the air sucking in. But, my question is, can i leave it off, can i put something over the opening on the throttle body (like a stocking or something ) to still filter what goes in? Are there any potential dangers from leaving it exposed?
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    less performance, because its sucking in hot air, no proper air intake so something could get into the motor, mr plod would probably give you a nice canary for it.
    The Black Beauty
    HSV.006's Avatar
    HSV.006 is offline Apprentice Mechanic
    vq statesman. CSV strada 5000i.
    Sep 2008
    adelaide
    ill admit its pretty fun too ay but probs not the best thing for your engine.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    just increased engine wear, thats all
    Body by Holden, Soul by Brock
    the Legend will live forever
    VP Executive R-spec
    Jan 2005
    Funny enough I did a gtech run in my old VN V6 just like that to see what happens and it was a couple tenths slower. Yes it made more sound but it was slower so you imagined that part of the story
    VP Exec S2 3.8
    Feb 2009
    Well mate no 2 cars are the same, and does make a noticible increase in performance. I havent imagined anything, I'm just concerned about hot air entering-
    VP Executive R-spec
    Jan 2005
    VP Exec S2 3.8
    Feb 2009
    Can i build something to cool the air entering the throttle body, that way i wouldn't be worried about hot air entering the motor. Obviously if the air entering dosent have to pass through a small passage into an airbox, through and airfilter, out of the airbox, up through a pipe, round a sharp bend before finally entering the throttle body, then is good right?
    VP Executive R-spec
    Jan 2005
    It only has to flow 400 cfm so long as the air is as cold as possible by the time it gets into the chamber you win since it only takes a splt second to get into the engine all you need to worry about it getting it from somewhere cold in the first place
    VP Exec S2 3.8
    Feb 2009
    VP Executive R-spec
    Jan 2005
    Yes just run a sealed pipe from the front bumper to the bottom of the airbox same as everyone else does
    VP Exec S2 3.8
    Feb 2009
    What do you mean by sealed pipe, like the silican pipe sections you can buy, or is it something else. Does the setion of pipe go all the way down past the bumper?
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    going faster wouldve been a thing of your mind cuz of it being louder you wouldve thought it was going better
    Eureka styles!
    VP Exec S2 3.8
    Feb 2009
    Well for ages now my car has been really hard to start, have to pump to gas and shift into gear without it stalling. When i put it into park or nuetral it would just stall. Fter removing the whole air intake, it started straight away and just sat thier idling for a few minutes no worries. What would have been behind this?
  15. #15
    Jan 2008
    qld
  16. #16
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Do you service your car regularly? If your air filter was REALLY clogged removing might make a difference.
  17. #17
    VP Exec S2 3.8
    Feb 2009
    Air filter was replaced couple of weeks ago along with plug's , leads, fuel and oil filter- still idled rough and was hard to start. Now that the throttle body intake is out in the open, it idles smooth and starts first go-?
  18. #18
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Okay. Removing your intake at the throttle body:
    no you have not gained power
    no this is not more efficient
    yes it will kill your car.
    Here's a few rules:
    1) colder air is denser, and makes more power
    2) your factory intake system flows more than your car will ever need
    3) more throttle response /= more power
    4) good air filters are ones that keep dirt out. this is a FAR more important characteristic than "flow".
    You've probably changed something else you've missed, which has caused the rectification of your strange problems. I'd suggest slowly reassembling the intake bits, and seeing at what point the engine goes all sloppy again Trial and error, mate. Trial and error. Don't ask us, we have no idea
    The 1972 HQ Kingswood
  19. #19
    danja's Avatar
    Jan 2006
    Quote Originally Posted by Daniel.B View Post
    Is there a dead hamster in your intake pipe?
  20. #20
    Morton's Avatar
    May 2006
    Quote Originally Posted by danja View Post
    I was going to suggest a nest of camels, but you're probably right.
  21. #21
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Keep the cat convertor. Keep the muffler. Keep the air intake.
    Maybe just sell the car and buy a bicycle.
  22. #22
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by 1991_Vn2nV View Post
    Or a Fiesta
  23. #23
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    how many bloody threads are you going to make? sheeeeeesh!
    go look at mortons old vp.... if you want a quick v6..... do what he done, every single step.......
    and as for your exhaust (cant be bothered finding the thread) the best flowing exhaust is on that goes straight into the cabin....... people will tell you otherwise but dont listen, what you need to do is cut a hole in the floor and it going directly into the cabin, trust me! 0-100 in less then 5 seconds..... *sarcasm*
  24. #24
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by padrickz88 View Post
    LOL...
    You can leave the intake off, just pull the dead sparrows and nests out every now and again. You were getting a rebuild next week right?........
    Reaper
  25. #25
    Morton's Avatar
    May 2006
    Damn straight ^_^ But in addition, remove power steering, and make it manual I can't explain just how 'perfect' a manual car with manual steering feels to drive And most kids these days will never know!!!
LinkBacks (?)
  1. 02-03-2009, 12:57 PM
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Leave Britney Alone!!!
    By holdensupporter2005 in forum Jokes/Humour
    Last Post: 28-12-2007, 12:00 PM
  3. please leave feedback...
    By MY_95_VS in forum Car Audio
    Last Post: 22-03-2005, 07:49 PM
