Hi guys,
This has got me completely baffled
Yesterday
Had an issue with the a/c throwing belts so i have replaced the tensioner pulley (which we believed was seizing) and put a new belt on.
Went to turn on the fan and it is not turning on.
Had a look at the relays first (swapped them around and all appears ok)
Next checked the fuses. When i pull out fuse 9: HEATER - A/C CONT AUTO A/C - CMPR - the car stopped running and I lost my instruments. But the fan came on.
Now fuse 10 is INSTRUMENTS - IGN SYSTEM (which are the things i lost when pulling fuse 9.
I am definitely not pulling the wrong fuse.
So to get the fan working i have to pull fuse 9 - which disables all the items described by fuse 10.
Today
pulling the fuse 9 still stops my car from running or starting - but now it no longer makes the fan turn on.
After sitting down and having a smoke and a can of johnny walker with the ignition in the on position, the fan magically turns on!! Then turns off. In a period of 15 mins it does this a couple of times. I can hear the realay switching in and out while it does this.
WHAT THE HELL IS GOING ON??
Which relay could you hear clicking?
blower fan relay - i was awfully patient and waited for the fan to magically turn back on with my fingers on the relay
By the sounds of things maybe its a bad earth on the relay
If you have a test light or multimeter, check to see if theres power on the heater blower motor/AC fuse when ignition is on.
I had a similar problem, turned out to be a bad earth on the ignition relay, which supplies power to the heater blower motor/AC fuse.
My VN wagon has an electric problem aswell, i have no aircon what so ever. The mechanics tried to re-gass it but did not work! any help? Cheers
