Hey guys, so ive had lifters ticking for sometime and i know that it isnt this new noise.
I drove my car the other night, stopped at home for about 1hour and then started my car back off, as soon as i put it in drive and took off i got a loud ticking which changed with acceleration coming from behind my dash.
I'm now wondering what this ticking is???
Speedo, tacho, fuel gauge all work well, temp never has with this dash and its bloody annoying me so all help is appreciated.
Sleeper Wagon - In the Build
VP Executive series 2
Check out My Ride
Current ModsWidened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy TuneFuture ModsNew CarWantedMONEY!!!
Could be the speedo cable? Does it only do it when you are moving?
yep only when moving, how could it be the speedo cable if its working perfectly???
Check out My Ride
It could be starting to fray and the wire is ticking against the outer sheath.
would that changing the pace at which it ticks through acceleration???
Check out My Ride
anyone else got any ideas, desperate to fix it
Check out My Ride
blown exhaust gasket?
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
very highly doubt it, only got done 2 months ago, its like right behind the dash, within the cabin
Check out My Ride
this may sound a lil stupid but--------
i had similar noise once - sounded like under the dash - pulled all dash apart and stuff -- long story short
my front drivers mudflap the nuts hoilding it on - there was one holding it on and it was flapping in the breeze and got worse with accellaration
dont have no mudflaps now so no noise lol
I'm with stocky. I'd definitely be checking the gasket between the head and exhaust manifold/header. When you car is stone cold, pop the bonnet, figure out how you can get your hands around the edges around of the gasket. Fire it up and quickly have a feel around for pressure leaking before it warms up, if it's a big enough leak you should be able to feel the pressure. This can be especially loud if for some reason you have a grommet missing from the firewall. If you're still not convinced, get a mate/family member/friendly stranger to stall the motor up a bit in gear on the brake, and stick your head under the bonnet and have a listen around. If you have 2 piece extractors, they're notorious for leaking at the join in the middle too, so check there as well. I'd be very surprised if this noise isn't some kind of exhaust gas leak. Just FYI, VN upward doesn't have a mechanical speedo cable. Hope this helps!
i remember this happening to me too.. i took the cluster out and behind it there was a time bomb >:0
*removes cluster* OH SHI-
Check out My Ride
Hey Abrowne70, how has it gone with the noise, cause I took my calais down the strip, and ever since I got that ticking too, started around 3k rpm, now around 2k rpm, gets slightly louder and fast as revs climb.
Anyone else got an idea for the prob, let us know, got me screwed (not gaskets either)
