Results 1 to 10 of 10
Thread: vt brakes on vp v8
    vp 5L
    Jul 2008
    goldcoast
    Default vt brakes on vp v8
    im buying some vt brakes to go on my vp v8 and what i want to no is,will the vt brake lines be long enough, i red somewhere that they will be to short, am i able to use the lines already on my car or do they have different fittings, if i have to get aftermarket lines what model ones do i ask for, if u say vt lines then wont i have the same problem them being to short if thats the case
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    u wont be able to put the discs on without the adapter hub -
    as for the brake lines not too sure ill be doin the conversion in a couple a weeks but the conversion kit comes with new brake lines anyway
    vnss
    Jan 2005
    s.e melb
    not sure why you need new lines but you just do lol, i got braided lines for a bit extra and im glad i did it.
    just a warning, the brakes will work better than the crap vn/vp brakes but they will be spongy even with the 1 inch master so look into changing over to a vt master/booster setup.
    you will need brake line adapters for the master cylinder cos your metal lines wont bolt up to the vt master (i paid $30)
    VT booster and master cylinder into a VN
    read that and you will get the jist of it
    vp 5L
    Jul 2008
    goldcoast
    im getting a price tomorrow on the hub adapters, but i think i can do it cheaper then buying the kit, so far its costing me
    vt brakes $80 pair
    rotors $120 pair
    pads $30-60
    lines shouldnt be that expensive and im going to fit it all myself , so i think i can do it alot cheaper then what the kit is worth
    Jun 2005
    hub adaptors will cost about 250, rubber lines i got for 59 i think, but braided were about 80 more
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You will need to get new brake lines. The ones off the vt calipers will fit in with your steel line but on full lock it kinks the line and the vr's dont work on the calipers. Any local reputable brake shop that makes lines will be able to make you an adaptor Vr-Vt caliper line set. Mine cost $90 for braided in the colour of my choice.
    Reaper
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Rather than use the hub adaptors would it be possible to fit vs front struts in a vn by using the vs lower control arms and the vn top strut plate???
    Vp series 2
    Jun 2008
    not sure but i am hoping so to.
    I have vr struts and arms here for that job with vy calipers.
    So i will be watching with interest.
    apparently you will need adaptor rings as the vt hub is larger in the centre and won't locate properly, they are about $30 on ebay.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by cander24 View Post
    No. The front track on the VR-VS is wider than the VP. You will need longer brake lines - spend the extra and get good quality braided. The pedal feel is much better. The hubs are readily available and an easy conversion, once again go for quality and avoid the cheap chineese crap unless you live a long way from Melbourne.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Vp series 2
    Jun 2008
    interesting, just done some research on the track width.
    vn/vp narrrow front and wide rear, irs a bit wider
    vr/vs wider ate front and rear, except vr/vs ute and wagon same at back as vn/vp.
    This is worth pursuing further.
    If the strut top centres are the same then a swap may be do able.
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. brakes
    By big m in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2008, 01:30 PM
  3. VN V6 brakes to V8 brakes
    By AngryVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2008, 08:27 PM
  4. new brakes
    By ned in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2008, 11:59 PM
  5. help with brakes
    By markandsam in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2005, 07:37 AM
