Results 1 to 2 of 2
Thread: Running bad and Ticky noise
    HAZZA-VN's Avatar
    HAZZA-VN is offline License back 11/02/2011
    5litre Calais
    Apr 2008
    Default Running bad and Ticky noise
    Running rough kinda misses hesitates before taking of some times, as if it was really cold but it can be at any time after driving it for 2 minutes or 3 hours but pretty consistent though if you put your foot down, runs like it on both gas and petrol.
    Okies getting a really really loud ticky sound when i start my car, hmm sounds like the injectors when it first goes of can hear it coming from there, it goes away after about 2 minutes of running. its still there just not as loud, Then after a while pull up at the lights and it does it again, goes away comes back goes away,
    It doesn't matter how long the cars been turned of for though turn it of for 30 seconds turn it back on and it does it again, I'm really starting to get P!ssed of with it i have put 20-60 gas oil in it made no difference put a bottle of injector fluid in and it did nothing again
    Cheers guys
    Speed never killed anyone. Suddenly becoming stationary, now that's what gets you...
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Harmonic balancer? Check it for cracks. Remove the belt and spin it, check for level rotation.
    The 1972 HQ Kingswood
  1. VS V6 running hot
    By jakewaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2008, 11:17 PM
  2. noise from middle / rear running gear
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2008, 11:42 PM
  3. VR VR Running Hot
    By Brutus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2006, 08:07 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
