Results 1 to 6 of 6
Thread: vs running gear into vn
    Wardy5441 is offline Vn wanting more power
    vn executive
    Apr 2008
    croydon
    Default vs running gear into vn
    hi everyone my name is dale i have a vn commodore and a written off vs and was wondering if the vs running gear will go straight into my vn and if the vs wiring loom will fit in as i want to transfer my vn to a ecotec and my trans is knackered so if any one has pointers can u please let me know as i want to do it asap
    Jul 2008
    i think its a straight bolt in, but aslong as you have all the electrics etc and are willing to swap them ( loom ecu bcm everything ) it may work
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If you have absolutely everything, it's easy (just time consuming).
    The 1972 HQ Kingswood
    Vp series 2
    Jun 2008
    yes take pics and number the wiring so you know were it all goes. you will want to swap the dash and front door trims to so it is easier to hook it all up.
    the front track width is different so not sure about the front end going in.
    i think the is a good chance as long as the distance between the strut top shafts is very close. otherwise the wheel alignment will never be right.
    Best to check with a engineer if it is legal to swap front ends.
    vn executive
    Apr 2008
    croydon
    hi i just want to swap the ecotec trans tailshaft and diff with the vs dash so no kframe or steering components thanks for your info to guys
    VR SS manual
    Apr 2006
    yeah not too hard a swap with the full loom will need to modify the loom in some place like the washer bottle etc in different spots
    ive just finished the conversion dash can be abit of pain but can all be done
  1. VT running gear into VR
    By COO1VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 01:41 PM
  2. VN calais everything but running gear
    By chunderlicious in forum Parts And Other Items For Sale
    Last Post: 02-12-2006, 04:31 AM
  3. Wtb - Vs V8 Running Gear
    By xcesiv in forum Swap / Wanted to Buy / Trade
    Last Post: 06-10-2005, 12:37 AM
  4. VT running gear into a VP
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 06:26 PM
  5. vn running gear into a vk
    By 5000iVK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-04-2005, 10:28 PM
Tags for this Thread
