Results 1 to 7 of 7
Thread: Testing Alterrntor and battery
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default Testing Alterrntor and battery
    ey guys got myself a multimeter to test my alternator and battery got a few questions though as im not sure what the voltage is suppost to be on both alternator and battery.
    So what setting should the multimeter be on?
    How do I test the alternator for voltage?
    And what volts should be going through the battery and alternator?
    Cheers for any advice
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    put your multimeter on volts u only need volts with one decimal place eg 12.5 volts
    your battery should be around the 12 volt mark normal
    when car is running should be around 13 - 14 volts
    anything less than 13 and your car isnt charging
    VY SS
    Jun 2006
    Albany
    put your multimeter on 20 DC volts, DC is the symbol with a line with dots underneath and AC is like this ~
    VP Exec
    Jun 2005
    A fully charged car battery should read ~12.6V across the terminals with the car off. With the car running, the voltage across the battery terminals should read ~13.8V at idle and rise to ~14.0-14.2V (and no greater) if the throttle is opened a little. It should stay at that level if you switch on some of the electrical load like headlights and fan.
    If you put the red voltmeter lead on the bolt on the back of the alternator with the thickest wire attached to it and leave the black wire on the battery earth terminal, you should get very close to the same reading as you do directly across the battery terminals.
    NO CAR ATM.. -.-
    Jul 2006
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    you can test your alternator by starting the car, turn the hi beams on then pull the positive terminal off the battery, if it keeps running you have a good alternator
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Quote Originally Posted by pr0n View Post
    that is the best way to kill an alternator.
  1. Epa Testing
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 03:18 PM
  2. EPA ADR testing
    By VN_Luke in forum General
    Last Post: 27-02-2006, 12:36 PM
  3. testing
    By spacattack in forum The Pub
    Last Post: 30-10-2005, 06:34 PM
  4. testing db
    By muffman001 in forum Car Audio
    Last Post: 11-06-2005, 12:34 AM
