Results 1 to 9 of 9
Thread: VP V6 starting problems when cold
    LX Torana-Hatch
    Jun 2006
    Default VP V6 starting problems when cold
    Hi,
    I have a fully rebuilt VP v6 motor fitted in an LX torana. I am having problems starting the engine when cold, it takes a fair bit of cranking >10seconds and coughs a bit. Once the engine is warm it starts well and from what I believe runs well
    We have had the engine checked over by a mechanic and he believes electrically it is fine. I have replaced the temperature sensor in the intake manifold, checked the coils, replaced the fuel regulator and replace the injectors with new ones.
    Any ideas of what to do next??
    Thanks
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is the fuel pump priming before you start it
    LX Torana-Hatch
    Jun 2006
    yes the fuel pump is priming. We did an error code check and no codes came up.
    Could it be the computer?
    Would I be best to source a new one or try a second hand computer?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    try find a known good ecu to test off someone saves buying it and not needing it
    NO CAR ATM.. -.-
    Jul 2006
    VP S2
    Feb 2009
    LX Torana-Hatch
    Jun 2006
    Yes it would be good to find someone with a good working ecu.
    I will have to find a manual one won't I as the engine is a manual.
    vg ute v6 5 speed
    Jun 2008
    hey just a thought my brother has a vr v6 he had the same prob it was the fuel pressure regulator at he back left of the fuel rail.
    worth a try ?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Quote Originally Posted by LX_HATCH View Post
    manual ant auto vn-vp ecu's are the same so are the memcals both auto and manual.if you want you can plug your memcal on as well so its running the same tune.
  1. VZ Cold Starting Issue
    By boofis in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-12-2008, 10:28 AM
  2. Cold starting problem
    By manta5au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2008, 03:15 PM
  3. VR V6 Starting problems when cold
    By Skywalker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2008, 06:23 AM
  4. Gas-cold starting
    By brett 46 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2006, 11:18 AM
  5. Starting up my VS from cold........
    By comitnycrym in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2005, 07:31 PM
