Results 1 to 12 of 12
Thread: swapping vp v6 motor into vn v6
    VN SV3800
    Sep 2008
    Default swapping vp v6 motor into vn v6
    hi guys
    my dad has blown up the motor in his vn but found a vp with a rebuilt v6 motor.
    Both motors have been pulled out and the loom looks about 95% the same. However, we have found that where the loom plugs into ECU in cabin, a little bit further up along the loom there is a 9pin plug and the vn v6 loom plug is different to the vp v6 loom plug.
    Any suggestions on what that connector does and how to get around this issue.
    Thanks in advance
    Andrew
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    just leave the vn loom in the car and extend the coolant temp sensor wires to the front of the engine where the sensor is on the vp engine apart from that everything should fit.and get a vp memcal to go in the ecu plugs straight in.
    Vp series 2
    Jun 2008
    on the end are 2 big plugs for the ecm then a little further up is the aldl connector which is only used to check for faults.
    take pics is the best way.
    you will need a vp chip to or it won't go properly.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    If you need a VP chip how come a VN chip goes better in a vp because its a slightly aggressive tune?
    ~ VN POWER ~ Click the scales
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the vn tune is totally different than vp and causes increased fuel usage when run in vp and they dont go that great with them either they do increase wot power but the rest of the tune is so far off you just waste gas.for vp ide suggest BAAM0265 memcal.
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Quote Originally Posted by Bz Kn33z View Post
    because some of the vn's had unicorn-horn-encoded encripts in their computers that just made it fly, duh? everyone knows that..
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Quote Originally Posted by Social View Post
    Well i'm so glad you cleared that up for me, are you the main supplier?
    social's Avatar
    Nov 2008
    South Aus
    nah man they were made back in the 90s we upgraded to dragon tooth since then as i said man get with the times!
    Black VN MANUAL
    Feb 2007
    Top of Vic
    wow that must be rare, i'm so old school thats why i have a vn and you have a vr
    social's Avatar
    Nov 2008
    South Aus
    yes they are rare to an extent, but its all about who you know oh mat eim old school too dont worry i worked hard thru my 1st vn then my 2nd a 3rd with a vl fell over to my 4th with a ford and finally last thursday reached the top with a vr
    Vp series 2
    Jun 2008
    don't worry mate mate when they atart on about unicorns and dragons, then you knowwho's comments to NOT to read next times as they have NO CLUE.
    Perhaps if your runs better without a vp tune then it has allready been chipped.
    This person has asked a serious question and you guys are speaking BS, please keep that for the FORD forums, you know you are closet ford drivers.
    vp
    Aug 2009
    ok so i have a vp we just put a a vn s1 motor in, and its not running lol. not getting proper injector pulse, any ideas> is there a plug or something that needed changing we havent changed yet>
  1. swapping ECU
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2009, 05:45 PM
  2. exhaust swapping
    By GH05T in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 06:32 PM
  3. Swapping springs.
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2008, 05:30 PM
  4. swapping gearboxes
    By Tekka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2008, 02:42 PM
  5. Swapping cam in VR VS V6 ?
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 02:36 PM
