Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Help identifying engine!
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Default Help identifying engine!
    Hey all, I have a 91 VN V6 which needs a new harmonic balancer. But in order to get the correct balancer I need to know what motor is in it exactly. I have suspicions that its from a VR because it has "VR" written on the intake manifold in texta. But need to find out if its actually from a VR or if its just the manifold.
    In other words, does anyone know any differences between VN, VP and VR V6 engines? Is it possible to find out via the engine number somehow?
    Cheers.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    well mate i could only tell you the difference between the series 1 vns and series 2 / vp / vr because the s1 has the radiator pipes running to behind the back of the engine where the others dont, hope that helps
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I should have mentioned that! Series 2 radiator hose setup btw. Thanks anyway.
    I have also noticed that the engine oil dipstick location seems odd as it sits under the top radiator hose which makes it tricky to remove. On our VP (lexcen if it makes a difference) its at the front of the motor. That have to do with anything?
    My (ex)Ride
    Black VN MANUAL
    Feb 2007
    Top of Vic
    S2 VNs have the oil dipstick at the front of the sump, insted of down the side of it, the top rad hose on a vp is like an L shape from radiator to manifold, on S2 or Vr engine it could be the same but the s2 vr engine is like the VS ones.
    Does it have a plastic protection plate over the CAS and around the Harmonic Balancer?
    ~ VN POWER ~ Click the scales
    VB SL/E
    Dec 2008
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Yes it has the plastic protection plate over the CAS.
    Probably wont show much but heres a quick pic from a few days ago:
    http://i243.photobucket.com/albums/f..._1300Large.jpg
    My (ex)Ride
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by VR38 View Post
    VR has crank angle sensor for duel fire system.
    Please explain.
    My (ex)Ride
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Cheers man. I guess Ill have to take the balancer off and go from there.
    While Im on the subject, would anyone know what size jaw puller is needed to take the balancer off?
    My (ex)Ride
    social's Avatar
    Nov 2008
    South Aus
    tbh mate the harmonic balancers are a b**** to do if you dont have the right claw piece, just make sure you get one with the claw bolts angled straight then at the bottom angles inwards otherwise it wont work, and to remove its a lock in to solid ground / cement or the engine bay chassey with the ratchet / breaker bar and quickly turn the engine over for a split second, it will undo the h / b quite fast if i do recall
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    The not-so obvious change from VP-VR is the addition of a cam-angle sensor in the VR engine, located just up and left of the water pump on the timing cover. The earlier engines are a little harder to tell apart. I tried to find a pic on google image search for you, but no dice. Good luck.
    By the way: I had my VIN number, year/month of manufacture, still with the original engine, and I still ended up with the wrong balancer. Just grab the most likely one, if it doesn't fit nicely, return it in its original packaging and most places will swap it over for you, with a small price adjustment.
    Edit: With Social's H/B removal tips, hitting the key with a breaker bar on the bolt, and against the pass side chassis rail is indeed the best way to loosen the bolt in the backyard, but make sure you rip out your efi relay first. :P
    Last edited by camstatic; 03-03-2009 at 08:30 AM. Reason: Citizens against flying breaker bars.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If you find the engine number beside the water pump outlet (will start with VH) I can tell you approx what month the engine was made.
    and 3 Dangerous non ABS VN's
    VB SL/E
    Dec 2008
    Quote Originally Posted by azzfox View Post
    Please explain.
    VN-VP fire all coils at once, VR fires three lots of twin/duel coils at separate times.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I had a look at the cas and it looks to be white. So Im guessing its the small cas and I need the VN/P balancer.
    Im aware that it will be a shitty job getting it off but Im not afraid to give it a go . 200+ lb/ft doesnt make it sound fun though . I have heard about getting the bolt undone that way. Bit iffy about it but probably the only way Im gonna get it off lol
    I couldnt find a cam angle sensor.
    Tried to find an engine number but its probably caked under a layer of crap . Ill have another look later when I feel like cleaning .
    My (ex)Ride
  15. #15
    Set of thongs
    Dec 2005
    Stonedville
  16. #16
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I just had another look and I found a suspicious sensor. Its sticking out the side of the timing cover just above the oil filter, and it has nothing connected to it. Could that be it? :S
    EDIT: Sorry, its not actually on the timing cover. But still I have no idea what it is lol
    My (ex)Ride
  17. #17
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    I always thought the VR engine had a S bend type rad hose which met up with the housing in between the p/s reservoir and belt tensioner, also your engine has the later coils.
  18. #18
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I believe that was for engines with ABS as the module got in the way.
    After some scrubbing I found the engine number. VH1203830
    My (ex)Ride
  19. #19
    VP S2
    Feb 2009
    probably the best way to pull these balancers off, ( particularly if you want to reuse it. ) is there are 3 slots in the front of the balancer. behind these slots are three 1/4 unf threaded holes. if you get a bolt type puller, you can use 3 bolts to pull on the centre. it can strain or break the rubber if you pull on the outer ring. hope this makes sense.
  20. #20
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    So there is threaded holes after all? I just thought there were none and needed the claw type puller to pull via the slots? If thats the case Ill just get the standard type puller.
    My (ex)Ride
  21. #21
    VP S2
    Feb 2009
    yep, and they are hidden a bit, but if you fish around in the three slots you'll find them.
  22. #22
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Took the thermo off and stuck my head in the bay to find a few threaded holes . Thanks for the heads up!
    My (ex)Ride
  23. #23
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    You should be able to get the right sensor with the engine number but theres a chance it might not be the orignal setup
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  24. #24
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Just going by the alternator in that pic, I'd be calling VR - but you never know. Engine number will be the winnar here I think
    The 1972 HQ Kingswood
  25. #25
    88GreenVN's Avatar
    Jun 2006
    I place that engine number to be June 1991.
  1. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  2. Identifying IRS?
    By Kstar. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 10:04 PM
  3. Help Identifying
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 09:04 PM
  4. Identifying VN V8 engine parts
    By jwk87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2006, 06:34 PM
