how do we adjust kickdown cable
you push the button thats on the t/b and pull out or in the plastic part thats holding the wire
so how do you when it is right
when i did mine i would drive and see.. if it feels like the transmission iss sliping or if it feels like its tight shifting
sory for double post but..
if it feels like its slipping make it more tight.. or if its too tight loosen it up
make sure your throttle butterfly is opening up all the way when ur cars turned off and have the intake pipe out..
so have a mate there with u to push down on the accelerate
when i drive the car it takes abit to change gears it stays in 2 end at 55 to 60 kph i dont i have been pushing the tab in and opening the throtle all the way open but i cant seem to get it right do i have to adjust the throtle cable to
to adjust kick down cable
1st press grey button and pull sleeve back (towards drivers side) as far as it ill go
2nd (with car turned off) open throttle body to the 100% open position - u will see kickdown cable adjust as u do it
3rd make sure you went to full 100% throttle - just turn the throttle as far as you possibly can
this will adjust it corectly
above thread is correct. they are self adjusting, just have to make them tight first.
Never late, in a 30..4 lol![]()
thanks guys
