My air con compressor makes a loud noise when not in use( sounding like a dry or shot bearing) BUT!!! the noise goes away when the air con is turned on ???
Any thoughts Anyone?
take off the belt and check the harmonic ballancer if it turns then you nee a new one and check all the pullys
sounds like the AC clutch bearing. the pulley turns independently to the AC compressor until its engaged by the clutch (when turning the AC on).
MY RIDE
Had the same prob with my vp and change the pump/re-gas and haven't heard a noise since, just be ready for a fight with the bolts on the bracket if they where anything like mine (TIGHT AS, AND TIGHT FOR SPACE)![]()
It's been about 12 years since I replaced mine on a VN. I'm guessing a bearing would cost $30-40 dollars and you need to remove the clutch and the aircon pulley to get to the bearing. I can't remember if the bearing is pressed in or held in with a circlip. They changed it in the VT and made it difficult to replace the bearing.
MY RIDE
MY RIDE
or just leave the ac on all the time..
no harm in that
Most workshops will refuse to change the bearing over and just offer to sell you an exchange pump. Last time I checked there was an abundance of aircon compressors for commodores on ebay, not bad pricing either.
the effect on fuel consumption is minimal..
i always left myne on when it worked.. n mum has hers one constantly and still averages 800ks to a tank
You will probably need to buy a whole new pulley because the bearing is sort of welded in and would be difficult but not impossible to replace. I assume you are talking about the pulley bearing. If it is noisy without the aircon on it's the pulley bearing and if it is noisy with the aircon on, then it is the compressor bearing.
MY RIDE
all fixed, it was the idler pulley next to it.. just brought 3 new pulleys gonna fit them tomara..
Calais for work... zed for pleasure
