knocked my commodore badge off look gay without it cos left bad outline of it
just woundering guys
how hell do i put it bad on i thought doubel sided tape
Yeh or superglue if you dont plan on taking it off again.
Have you tried polishing where the badge was?
no longer a hoon by association - the commodore is gone
yeah i was poilshing my car when i took it off cos thought it wld be nice
but looks ****ed
were wld i get the tape wld superglue work
Not too sure how the normal double sided tape will hold up when your car gets wet????? Superglue would work but you will have a world of trouble if you ever want to take them off again.
sikaflexx??????
like a rubber cement. once its on it takes alot to get off. You can pick it up at a paint and panel supply shop
so its called sikaflex
alot other people said the double sided tape its like super strong
can u get the sikaflex from buddings
i wouldnt use double sided tape - its crap - go down the local panel beaters - they prob charge like 5 bucks for a dab of it to keep the badge on
i reckon debadgin a car only looks good if you do all the badges
sikaflex must DIE !!!! still cant get it off the side of my ute. just cut and polish where the badge was dude and it wil turn out sick.
SIR LS1
the two ton go kart
i have cut n poilshed it heaps its not coming out
so wat should i do get sikaflexx from bunnings
use areldite.
SIR LS1
the two ton go kart
its like the uncoat of the paint is showing thou so i dnt think anything will get it off besides repaint
whats areldite
a clear sealant.... very rubbery when it sets so if it ever has to come off it can be peeled of easier than sikaflek. that shits like concrete
SIR LS1
the two ton go kart
thanks guys
Sikaflex if you want it to stick with the option of removing, Araldyte if you never want it to move again.
The 1972 HQ Kingswood
wot ppl are saying sikaflex it will never come off now ur saying other ahha im so lost
meh i cant get mine off . mine ( pics of my ute in my thread ) is stuck on there
SIR LS1
the two ton go kart
Basically, sikaflex will come off with elbow grease and solvents.
Araldyte will come off with your paint![]()
i can not get sikaflex off my ute and its driven me crazy. even spray painters tell me im going to have to respray it
SIR LS1
the two ton go kart
davecunno try a carmel wheel take it to a beaters they should do it for you cheap trust me it the only thing that will do it ive taking the black strips off the door on two vts and a vr it will do the trick
already asked a few panel beater customers... it wont fix this stuff. this stuff is BADLY solid
SIR LS1
the two ton go kart
