Results 1 to 15 of 15
Thread: vn 90 exc
    vn90
    Dec 2008
    Default vn 90 exc
    is a vn 90 exc s2 or s1
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    mate start doing some searching ... its not that hard to find the answers u need rather than starting heaps of threads. vn 90 had s1 and s2 if the thermostat is at the back of them motor its a s1
    SIR LS1
    the two ton go kart
    vn90
    Dec 2008
    i did look mate thanks for ur help im new to cars would u mind telling me what a thermostat looks like
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    if u look at the side of you motor on the drivers side there will be a cooling pipe above the spark plug moving along to the back of the motor.... thats a series 1
    if the top of the radiator pipe goes to the front of the motor its a series 2
    SIR LS1
    the two ton go kart
    vn90
    Dec 2008
    ok i went had a look the raddy on the driver side there a think black hose then rungs towards driver then drops down where it says 3800 on top mainfold has lil pipe coming out side of it
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    is it a pipe that runs along the side of the motor the the back or does it go to the front
    SIR LS1
    the two ton go kart
    vn90
    Dec 2008
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    get a pic up if u can but id say its a s1. wheres the alternator located
    SIR LS1
    the two ton go kart
    vn90
    Dec 2008
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    vn90
    Dec 2008
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    vn90
    Dec 2008
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
  15. #15
    vn90
    Dec 2008
    thought so all good thanks mate
