Results 1 to 15 of 15
Thread: A vvvvvvvvvvvvvvvver noise
    vn90
    Dec 2008
    Default A vvvvvvvvvvvvvvvver noise
    hey guys theres a vvvvvvvver noise coming fron the back of my car i think.
    only goes for like 5 secs after i turn car off
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    when you turn the ignition to ON (not actually starting the car), does it make the same sound as your describing?
    If so, its the fuel pump.
    vn90
    Dec 2008
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    vn90
    Dec 2008
    SORRY it does happen when i turn it just for like 2 secs then stops
    so what is it n does it needa be fixed
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    thats just ya fuel pump mate when u turn your car on - it primes for a few seconds - and sometimes when u turn off it releases that fuel to the tank
    vn90
    Dec 2008
    so everything is ok i w asnt worryed about it
    just woundering wtf it was lol
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    usually if it makes that much noise you got no petrol or its on the way out so if it stops one day and wont start again thats where id looked
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip fuel pump it will keep running untill the oil pressure in the engine drops after you turn the engine off
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    thats a interesting point, even if your car is turned off and your inside, should your pressure drop does the pump kick in auto maticaly to keep pressure up for you to start it next time?
    or does it pump up to pressure like crazy at start up,
    i am the god of britany spears womanizer on just dance on the wii
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nope just primes at startup you shouldnt loose pressure anyway unless you have leaking injectors,regulator or leaky non return valve in the pump
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    sure the mrs is hiding in the boot with a elecy toothbrush?
    VZ SSZ- LS1
  15. #15
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Quote Originally Posted by BANKS View Post
    You sure it's a Toothbrush
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
  1. New Noise ... HELP
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-07-2008, 09:59 AM
  2. bad noise
    By kmbattle in forum Car Audio
    Last Post: 03-04-2006, 10:11 AM
  3. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
  4. Noise is still there!!
    By Butcher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2005, 02:03 PM
  5. Gen III V8 Noise.
    By Jaime S. in forum General
    Last Post: 10-01-2004, 01:24 AM
