Results 1 to 13 of 13
Thread: Removing Injectors
    vp berlina 5.0
    Nov 2008
    Default Removing Injectors
    G'day
    im pulling out the injectors for a clean and was just wondering if someone could give me the run down on how to take them out on a vp 5.0 as i cant afford for the mechanic to do the lot.
    thanks !!
    VP Executive R-spec
    Jan 2005
    Yeah, you just undo the fuel rail (4 bolts under the plastic caps) then lift the rail out of the manifold, then unclip all the injectors (both the clips on the plug and the clips on top of the injector holding them into the rail) and pull them out. If you feel like you might have a unco attack put a soft rag under them as you pull them out so you don't bash them into something and break the tips off them as they are a bit fragile
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    on mine i also had to undo the 2 fuel hoses that go into the ends of the fuelrails either side
    no biggy just a flat head screwdriver to undo as your lifting them out
    vp berlina 5.0
    Nov 2008
    Quote Originally Posted by greenfoam View Post
    no worries then sounds easy enough ,but that unco attack is always possible especially not knowing what im doing.
    thanks
    vp berlina 5.0
    Nov 2008
    May 2006
    Perth, Western Aust
    yeh dont stress lol u cant go too far wrong - and when ya undo the fuel hoses etc a tiny bit of fuel will come out - not too much so dont worry its normal and yeh as said before with the clips holding the injectors on be careful with em -
    BTW how are u cleaning them - i took mine to the local watchmaker who stuck em in his ultrasonic cheap as - they comeout fine from that
    VP Executive R-spec
    Jan 2005
    You dont need to get the fuel hoses off to just remove the injectors without the whole rail but I guess if you do take the whole lot out you will save on the possible unco attack
    May 2006
    Perth, Western Aust
    yeh i found it easier that way myself least ya not leaning over the car with the possibility of dropping one of those injector clips - besides its only 2 easy screws to get the fuel hoses off
    vp berlina 5.0
    Nov 2008
    ok so if i undo the fuel lines as well i can take the fuel rail thing out to and the injectors will be in that ?
    i thought the injectors were stuck in the manifold ?
    im already confused !!
    May 2006
    Perth, Western Aust
    nah the injectors just sit in the manifold they are clipped by the top bit to the fuel rail with a big circlip looking thing so if u lift the whole fuel rail out the injectors will be attached to the fuel rail and will slide straight out of the manifold - dont forget to unplug the injectors of course lol....apart from the bolts holding the fuel rail (and injectors) in ---- is the 2 fuel hose at the very end of the rails and they are easily removed if i get time tomorow ill take some pics
    vp berlina 5.0
    Nov 2008
    yeah if you had a photo that would help out a LOT....i sorta got the idea now im gonna do it on sunday so i got a whole day not just a couple of hours.
    '90 S1 VN 3.8L A4 Wagon
    Feb 2009
    how does one clean the injectors with average equipment? whats recommend and what should i avoid ?
    You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
    May 2006
    Perth, Western Aust
    i dont think there is average equipment to clean em - ultra sonics are hell expensive, im just lucky we got one in the family - but they give the best clean
  1. help on removing a/c when removing engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 02:19 PM
  2. Removing VN V6 injectors
    By Shortstuff in forum Holden Commodore How-To's
    Last Post: 01-02-2008, 08:19 AM
  3. maybe injectors?
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 10:59 PM
  4. Best injectors.
    By Frd_thmsn in forum V6 Development And Modification
    Last Post: 24-05-2006, 06:57 PM
  5. Removing Injectors
    By shaggerz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2005, 01:22 PM
