Results 1 to 7 of 7
Thread: Running on 5
    VN Calais V6 S1
    Feb 2006
    Newcastle, NSW
    Angry Running on 5
    VN V6 suddenly running like crap, one of the injectors isnt firing.
    There is no change in idle when i pull the electrical lead off one of them.
    The spark plug is gettin plenty of spark, so i dont think its the coil pack.
    I tested the resistance on that injector and its the same as the rest. (16 ohm) or something.
    I also know that the electrical wires to the injector is fine.
    Is the injector stuffed??
    im hungry
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    it sure could be easiest way to check is to swap it round with a working one take ya 10 mins to do it
    VN Calais V6 S1
    Feb 2006
    Newcastle, NSW
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Take the cable clip out of the back of the manifold so you have a bit more reach with the injector wiring, jump the plugs one forward each so you can test to see if this injector that isn't firing, will fire (obviously if it does, this indicates a wiring fault, easy enough to fix). These engines fire all the injectors at once so it shouldn't be a problem.
    May 2006
    Perth, Western Aust
    yeh try that ^^^^ or take the fuel rail off and swap a coupla injectors round so u can tell thats its definitely that
    VN Calais V6 S1
    Feb 2006
    Newcastle, NSW
    I feel sooooo stupid, it ended up being the frigin spark plug. For some stupid reason i checked the spark going to the spark plug but not the spark plug itself, I learned heaps from it in many ways anyway. Sorry to hassle. Its all good now. Thanks for your help
    im hungry
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    Good to see she's sorted.
  1. its running, what should i do now??
    By orreal511 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2008, 11:01 AM
  2. VC running bad
    By patullose in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-01-2007, 02:09 PM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. VC with a 202 running in
    By Joes_meat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-04-2005, 03:02 PM
  5. how do i keep my vk running well??
    By VksupaNoob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-02-2005, 09:23 PM
