Results 1 to 5 of 5
Thread: Alternator not charging, no alternator light
    VN SS. VN V6 speedwagon
    Oct 2007
    Gold Coast
    Default Alternator not charging, no alternator light
    hi there guys,
    I have a VN SS, just recently i bought a damaged VN V6 calais and swapped the entire body loom over so i could have all the calais options.
    Now the problem is that the alternating is not charging the battery and the warning light in the dash is not illuminated
    i tried using the alternator out of the V6 and dodgied it up to fit on the V8 but that resulted in no charge either.
    just wondering why the light doesn't work, it doesn't even light up when the key is switched to on.
    BTW the car has been running with that loom and did approx 100km before it died so it must have been working for a bit then died.
    thanks, wayno
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Bulb?
    I've gotta write this for the 10 character word limit >_<
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    Oct 2007
    Gold Coast
    i'll just try that now, didn't even think of that
    EDIT: Nope, the globe works, even tried the old level 2 cluster in there and still no light when turning it to ON
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Is your sensor wire hooked up to the battery cleanly and properly? (fusable link too)
    Oct 2007
    Gold Coast
    Quote Originally Posted by camstatic View Post
    thanks camstatic, the fusible link was ok, but the other wire coming from the alternator back towards the dash wasn't connected. Of the three plugs that connect the engine loom to the body loom, the brown wire coming from the alternator was in the smallest connector with only one other wire, However the calais loom had the brown wire in the largest grey connecter
    All working now, thanks for the advice.
    wayno
  1. Charging problems? wtf? (alternator?)
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2008, 09:08 PM
  2. Battery Light On, Alternator or something else?
    By phaze204 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2008, 09:28 AM
  3. VX Alternator Light Always on.
    By Raggyman in forum Electrical Wiring / Questions
    Last Post: 25-10-2005, 07:34 PM
  4. alternator light comes on then goes off intermitently
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 06:24 PM
  5. flickering alternator light
    By Tony2 in forum Electrical Wiring / Questions
    Last Post: 22-04-2005, 08:46 PM
