Results 1 to 12 of 12
Thread: vs fuel pump fit in vn
    Phat VN's Avatar
    Phat VN is offline Fangin calais
    VP Calais 92
    Oct 2008
    Kersbrook S.A
    Default vs fuel pump fit in vn
    hey how ya doin
    well im sick of running my car on gas my fuel pump is stuffed and i want more power out my car so i thought pettie would b the way there is this guy that is giving away a fuel tank and tail shaft and was wondering if the vs fuel pump would fit a vn S1 any ideas anyone
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Get your gas tuned properly. Gas has a higher octane than petrol and tuned correctly will have more go than petrol. You will use more gas but not as much as petrol.
    And no, the VS pump is different.
    Visit my Facebook page
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    As far as i know all fuel pumps from VN S1 to VS S3 were the same might be a difference if its a interceptor tank ie-length but yer all the same!
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    running vp v6 fuel pump in my vs v8 . there all just the same bosch fuel pump
    SIR LS1
    the two ton go kart
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    apparently they are different, they look the same but have different preassurse i think??
    but i know they have different part numbers
    series 1 has a different fuel pump however i pretty sure vn series 2 to vs use the same pump...
    Morticia's Avatar
    Morticia is offline Sneaky Bastard ;)
    VY commodore
    Feb 2009
    I dont think the vs fuel pump can fit a series 1 vn... let me find out for you
    [Windows OS detected... Please standby for errors]
    Morticia's Avatar
    VY commodore
    Feb 2009
    Nope they are not the same...
    If you had a series 2 VN you could get away with it.
    But the Vs fuel pump doesnt fit the Series 1
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Thank you....I get a warm fuzzy feeling when I am right...hahaha.....
    Phat VN's Avatar
    VP Calais 92
    Oct 2008
    Kersbrook S.A
    wat should i ask (to get more power) when i get my gas tuned cause funni thing i made an appointment for tomorrow should i say can u make the tuning so i get more power
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    Phat VN's Avatar
    VP Calais 92
    Oct 2008
    Kersbrook S.A
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You can't have a system that is really good on both petrol and gas, one will always be better than the other, just the way the two fuels are. If you are never going to run it petrol again you can up the gas pressure and tune the O2 sensor out but that would mean a new memcal.
    Have a look at this site....RageLPG.com.au: Home
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
