Results 1 to 11 of 11
Thread: Engine Knocking at Idle..
    VP Commodore
    Mar 2009
    Arrow Engine Knocking at Idle..
    There's plenty of threads around with similar sort of issues and I read through them but i couldn't find one with exactly the same symptoms.
    I replaced the water pump in my VP about a week and a half ago and there were no leaks/car was running well and not too hot.
    I drove it to work the other day; and when I started it after work thats when I noticed the knocking sound coming from the engine.
    I did an oil change and replaced the filter with a Ryco one but it doesn't seem to have fixed the problem.
    The sound only occurs when the engine is idling, but it does it in all the gears, including Park. It's sort of a metallic knock but not tinny it sounds a bit like a rattle even.
    Once I begin to accelerate the sound goes away and I'm pretty sure it's not just being drowned out, because I've had the radio off/windows down listening for it, It doesn't sound like it's getting worse but I can't imagine its great for the engine to be driving round if there's something wrong.
    Any help/advice would be greatly appreciated as I'd rather not have to get the engine taken apart/pay for the labour for that if there are other possible issues that are causing the noise.
    cheers
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    Sounds a bit like a problem I had recently with my harmonic balancer, not sure if you read that thread but here it is: Loud rattle noise from motor
    There's a sound file in there showing my stuffed HB so you can listen and see if it's the same.
    VP Commodore
    Mar 2009
    Quote Originally Posted by Azp View Post
    Yeah that recorded sound file does sound like it..thanks for that..Did you get yours fixed/how much (roughly) did it cost?
    vb sle
    Jan 2009
    adelaide
    vn
    Feb 2009
    check the rubber on the harmonic balancer for crakes or take the belt off and turn the harmonic balancer by hand if it moves its stuffed if it doesent its fine then looke at all the pulleys if there is nothing wrong there check the cat if that is ok then it might time for engine rebuild hope that helps
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Exclamation
    Check your engine oil pressure sound like the start of some big problems!
    Does it sound like a knock or a tap?
    Could be a lifter if its a tap, when your drivin the outside noise can drown it out.
    But if its a knock then get your car checked before its to late!!!!!
    VP Exec S2 3.8
    Feb 2009
    mine does this on idle aswell, VP V6, but i also get the same noise under full acceleration at higher revs, as i don't have a tacho, im guessing between 4000-5000rpm, sounds really nasty too at those revs, does your do this aswell?
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    Quote Originally Posted by jtyoss View Post
    Yeah I got mine fixed for the price of the balancer which was about $130NZ second hand. They're about $230NZ new over here but saw in some threads that you can get them new for $150 or less in Aus. I did the work myself so didn't pay labor. Very easy to do if you or a mate has a good rattle gun and a suitable puller. Wouldn't take long for a mechanic to do anyway because it's just one bolt.
    As mundine said, check the rubber around it. Mine had a large chunk of missing rubber and a crack going through it. With the driver belt off I was able to rotate it by hand.
    Quote Originally Posted by Daniel.B View Post
    I can't say if mine did it at high rpm because when it started making the noise I pretty much just limped it home fairly gently.
    VP Commodore
    Mar 2009
    Wink
    thanks for the responses guys.
    Its definetly more of a 'knock' and less like a tapping noise.
    I've got some time this arvo/sunday to have a look at the car so Im going to check the Balancer etc so I'll post any updates. The oil pressure seems to be ok though.
    It's not being driven at the moment so at least the problem cant get worse
    VP ute
    Mar 2006
    I had a knock that turned out to be the fuel pressure dampner (not the actual name). It sits in behind the throttle body. It is not the pressure regulator, it is another part that looks kinda similar just near it. Drove me crazy till I found it
    vp executive
    Sep 2008
    i ha a rod bearing get thrown and the first thing i did wass take the drive belt off to see if it was that damn balancer but nope it was a rod bearing when i took it out n tore it down. in the end i had gotten a wagon with a stuffed gearbox for 300 so i put the motor into the sedan and just recently got a really primo motor for the wagon n its all back to good now.
  1. Knocking noise only at idle and in drive.
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2010, 12:37 PM
  2. Engine Knocking so i need another
    By DArtaganan21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 05:20 PM
  3. Engine knocking
    By d_neo_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 10:09 PM
  4. VT 5.0L Engine Knocking Noise?
    By Spitfire in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 08:06 PM
  5. engine knocking noise
    By grigor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 06:06 PM
