Results 1 to 10 of 10
Thread: VP heater not going
    VP Executive Wagon 93
    Mar 2009
    Question VP heater not going
    Just bought a VP wagon a while ago. Heater was not going. Finally got around to having a look at it, and think I have it sussed. Both hoses that previously went throught the firewall into car, have been cut off. Does anyone know why this would be? Would the heater inside be stuffed?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    hook them up it could of been a blown hose and they couldn't be bothered to fix it or the other problem could be that the heater core in your dash has a leak i'd try hooking up new hoses as it's the cheaper option just fill it with water for the first test!
    Vp series 2
    Jun 2008
    vn
    Feb 2009
    Mar 2009
    Default Cheers
    Cheers guys for the replies. I'll give that a crack next weekend and see how I get on. I presume if it's leaking I'll easily be able to see the water leaking inside the car.
    VS l67 statesman
    Dec 2008
    You probally wont see any water inside the car it will drain directly above the front of the gear box out of the Ac drain,Also it migth not leak until everything is hot and under pressure,be aware of this before taking it for a drive if it doesnt leak striaght away because they can blow out if they have a leak
    Mar 2009
    Is there anyway to check the core without going for a drive? Also which way round do the hoses go. Very much a novice at this - practical but don't know alot about cars. And was also wondering what Da_rooster meant when he said fill it with water first.
    VS l67 statesman
    Dec 2008
    fill it with water ,Idle until operating temperature ,icrease revs if you need to ,while the heater is on and wait for a hiss or bang & water everywhere under the car , its a lot of fun(Not) lol I speak from experience
    VN S1
    Jan 2008
    What side of the firewall? Im hoping your not talkin about the original air conditioning high pressure lines lol.
    Mar 2009
    They are on the drivers side of the fire wall. Don't think they are air con lines, just rubber, about an inch thick or so. Car doesn't have air con as far as I can tell.
  1. VN V6 S1 Heater Tap
    By Bugsy27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2009, 11:05 PM
  2. VS Heater Fan
    By VQ Stato in forum Electrical Wiring / Questions
    Last Post: 12-12-2008, 05:58 PM
  3. Heater Tap
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2006, 08:42 PM
  4. Heater TAP???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 11:16 PM
  5. Heater
    By gospeedracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2004, 04:00 PM
