Results 1 to 3 of 3
Thread: Coolant leak VN Ser1 Inlet Manifold
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Default Coolant leak VN Ser1 Inlet Manifold
    Noticed a few tiny spots of coolant under our VN & the smell of oil in the coolant, aswell as a strange hi & low idle occasionally.Was alwaz spots of coolant at the rear of the engine on the ground.As it's a ser1 i 1st thought it was the thermostat pipe hose clamp.However after a few more spots ova a few days i got in 4 a betta look.It's leaking coolant from around no5 & 9 bolt.Snapped a pic if it helps sumbody.I'm expecting more than just an inlet manifold gasket blown but howeva a bad case of alloy corrosion ,offfs & it'll need welding or perhaps of 2 u pull it wreckers 4 another inlet manifold, but there's another lottery coz u can't tell wat they're like til ya pulled it off..??Had this same problem with my son's ser1 & had his welded.Not had our VN long..
    Attached Thumbnails Attached Thumbnails Coolant leak VN Ser1 Inlet Manifold-inlet-maniolf-leaks.jpg
    Tony 308vkcalais:
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip happens on most vn-vp's after a while inlet gaskets just give up in the end
    vb sle
    Jan 2009
    adelaide
    could also be rear welsh plugs
  1. inlet manifold leak V6 VP
    By jonnydico in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2008, 01:09 AM
  2. Possible leak in the inlet manifold
    By neobristol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2008, 07:27 AM
  3. inlet manifold gasket leak?
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 09:50 PM
  4. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
