Results 1 to 3 of 3
Thread: vp missfire
    vp commodore
    Mar 2009
    Exclamation vp missfire
    gday my vp has had a missfire and engine backfiring under load since engine swap, changed plugs and leads, replace the coil packs and dfi module, misfire occurs in no.6 cylinder as i unplugged no.6 injector and found engine still misfired. so i swapped leads over on the coil pack and misfire is worse. would there be a problem with the crank angle sensor or would there be an in ternal fault
    vp commodore
    Mar 2009
    Angry
    Quote Originally Posted by godsey265 View Post
    i found the problem as the evidence didnt show until before, the v6 decided to blow a head gasket, coolant bubbled up, had oil sludge through the cooling system. so the misfire and breaking down under load was the bloody head gasket.
    Vp exec
    Feb 2009
    Melbourne ;D
    yeah thats similar to mine
    but a little diff
    when i put my foot down the car would like near stall
    then it clicked and i changed my fuel filter and got it serviced and new exhaust cause exhaust had a hole in the manafold or something like that so no pressure
    and now she runs like a dream
  1. vn missfire on start
    By fisher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2008, 05:43 PM
  2. Vn Missfire
    By jetoblaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2008, 08:24 PM
  3. random missfire
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 04:02 PM
  4. Missfire at idle...
    By Sorak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 10:09 AM
  5. Vs Missfire
    By Chris Everett in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2004, 05:56 PM
