done check on my vn today
and i got the code 13
dnt no much about cars so is this bad
and how should i deal with it
Its not to bad, it will be going through the fuel fast, its the O2 sensor (exhaust sensor), is it stock exhaust manifolds? i put pacemakers on mine and insted of it being on the extractor its on the Y pipe about 2-3inch from car, and comes on alot, and when its boosted it comes on more.
So take it out clean it put it back in and if its still stuff just buy a new one.
~ VN POWER ~ Click the scales
yeahh just normal extors were wld it be on vn
passenger side collector pipe.
or header as it is also called.
you will see a wire or 2 depending on the model of your vn
passenger side, take the air intake off the 3inch tube and look on the exhaust , the sensor is there i think its a 19mm i could be wrong just unplug it and the get a shirter or spanner and take it off it unscrews. does it stay on all the time, or off and on?
it goes on n off
