Results 1 to 8 of 8
Thread: EF thermo fans onto VN V6
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default EF thermo fans onto VN V6
    I know the AU shroud is a bit better size for the earlier Commodores, but I have a set of EFs in the shed and want to fit them to the VN. Anyone done this before who can offer any tips as to how to physically fit the fans with an efficient shroud setup?
    WTB: mulberry VN interior parts
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Generally, they need a bit of a trim. From what Ive seen, people test fit, trim, fit again.... etc. Use a grinder to get nice flat edges, and then cable tie on top and bottom
    Since the fans are fully contained within the setup, they are already shrouded as well as needs be - they don't need that huge sticky-out shroud that Holden are so fond of
    The 1972 HQ Kingswood
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    morton sam has enough cable ties holding his car together, he doesnt need more
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    with the au ones on my car - i only needed to trim the sides where the top and bottom hoses are - the rest was an easy fit - id imagine ef;s would be pretty similar - when i went to the wreckers to get mine though he said au where the way to go - ef;s werent as long i think whereas the au ones cover the radiator properly
    cant quite remember - mite be lenght or height there was one thing he said is why everyone buys the au's
    Morton's Avatar
    May 2006
    Quote Originally Posted by Zuicider View Post
    Don't talk to me about cable ties hahaha
    Screws and bolts are for keeping in jars. Cable ties are for keeping your car in once piece
    There's nothing better than a quick-release fan shroud for that emergency cam swap
    Set of thongs
    Dec 2005
    Stonedville
    haha dont get sam into the idea i will end up doing it, he is already getting ideas for making a turbo set up like lukevn's old six and looks like i will be making it
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    lol yep
    AU are the better fit on VN/Ps, the EF are slightly too wide from what I've read. I need the room up front though for the turbo setup and the EF are meant to be slightly slimmer so let's see what happens
    As for test fitting time and again, that's the plan I'll take plenty of pics as I go too if I remember, that way nobody will need to ask this again
    If anyone has any ideas on wiring them in, please see the thread of the same title in the Electrical section!! The EF fans have dual speed control, so does the VN output, just not sure how to put the two together
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Seems there is no way in hell these are going to fit snugly against the radiator. Even if I chop off everything that isn't fans, i.e. the ENTIRE shroud, they are miles too wide.
  1. Thermo fans into a VC
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2009, 02:46 PM
  2. WTB EL to AU Thermo Fans
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2008, 05:40 PM
  3. thermo fans
    By jonohall in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2008, 02:19 PM
  4. THermo fans
    By dave0103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2008, 08:48 PM
