Results 1 to 7 of 7
Thread: Power Window Upgrade
    2002 VX II Acclaim
    Aug 2008
    Default Power Window Upgrade
    How you going guys. Im wanting to upgrade the windows in my VN Wagon to electrics.
    I know i need regulators for all 4 doors, the wiring loom to all the doors and the actual power window module that has the 4 switchs on it.
    My question is, once i have the loom and ive ran it all and connected it, Where does it plug into to? I know it connects inside the doors and to the switch block, but the other end where does it go? To the computer? or does it just need 12v?
    Also im assuming the wiring loom from a VN-VS Statesman will fit the VN Wagon?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    there is a large internal loom you will need to get with a power window module that runs from under your dash to all the doors
    2002 VX II Acclaim
    Aug 2008
    Thats the loom i was talking about., I know that runs to all the doors, but then where does the other end go to? I know it connects to the window module witht he switchs, but does it connect to anything else? or just 12v?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Window control module mounts just under the steering wheel. Retagle box and its black
    and 3 Dangerous non ABS VN's
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Search function is great for questions like these.
    Go to Post #44 in this thread> How to install Power Windows.
    Might give you an idea of what should connect where.
    VN S1
    Jan 2008
    Yeah but can you do this without using a window module.. i cant see why its needed really.. basic electric principles say it should be able to be hooked up to run without a module.
    2002 VX II Acclaim
    Aug 2008
    Yer thats what i wanted to know. I dont mind not having auto window up etc (apparently my keyless entry system is capable of handling that on its own.)
    I just havent been able to source one out on ebay.
    I was honestly planning to just run the new loom throughout the car, skip the module and have it all controlled manually from the switchblock in the centre console.
  1. Power Window Kit for VX
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2010, 11:12 AM
  2. ecotec v6 VY power upgrade, what was it?
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 05:44 PM
  3. 3 window Instrument Cluster Upgrade!?!?!
    By breast69au in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-09-2006, 11:49 AM
  4. Power upgrade: Blown or Stroked
    By HSV1992 in forum V8 Development and Modification
    Last Post: 13-09-2005, 11:22 AM
  5. MORE POWER FROM VT5.0 195kw UPGRADE
    By broomie21 in forum V8 Development and Modification
    Last Post: 01-09-2005, 11:44 AM
