Results 1 to 17 of 17
Thread: Won't Start
    VN Commodore
    Mar 2009
    QLD
    Default Won't Start
    HI,
    VN Commodore wont start, it is not the battery and it is not the starter motor. What else could it be?
    Thanks.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    CAS or the coils could be a good place to start. Is the fuel pump buzzing into action when you turn the ignition on?
    and 3 Dangerous non ABS VN's
    VN Commodore
    Mar 2009
    QLD
    No, there is nothing when you turn the key, there is no dash lights or anything. It was working a few weeks ago, made no changes in that time and went to start it yesterday and nothing.
    88GreenVN's Avatar
    Jun 2006
    No dash lights - battery connection could be corroded. Also you could check the earths next to the battery.
    VN Commodore
    Mar 2009
    QLD
    Could it be the electrics to the ignition? Just wait for my husband to get home so he can check what you said because I would not have a clue. He is just getting really sh*tty because the car wont start, so trying to find out what the problem is for him.
    VN Commodore
    Mar 2009
    QLD
    He just came in and said he checked those 2 things first, so it is not them any other ideas!!??
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Does any of the accessory's ie. radio,wipers turn on at all?
    You could check the ignition fuse, and all the fusible links located above the battery, although it does sound like a dead battery. You need a multimeter to test its voltage, should be around ~12v when car is off, then try jumpstart it, it should be charging at around 13.9-14.4v.
    VN Commodore
    Mar 2009
    QLD
    We have jumpstarted it with my car and also put my live battery in it, so it is def. not the battery. When we jumpstart and turn the ignition on the car just does nothing. It doesn't turn over, none of the instruments come on. The only other thing is when we used to start it we had to jiggle the gear stick in between gears to start it, it is an auto btw. Dont know if that would have anything to do with it.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by jessicavictor View Post
    The inhibitor switch on the auto can stop it from starting, but you should still get ignition lights on the dash. I'd be getting a multimeter and checking to see if you have power at the ignition barrel, fusible links etc..
    VN Commodore
    Mar 2009
    QLD
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Everywhere sell them, most spare parts like Supercheap, Autobarn, Repco. Also K-Mart, Big W, Dick Smiths...
    Come in very handy for problems like these.
    EDIT: Just a cheapie - about $15.
    VN Commodore
    Mar 2009
    QLD
    88GreenVN's Avatar
    Jun 2006
    There is a how to fix the reverse switch on this forum unde VS I think. Have you tried starting in neutral?
    VN Commodore
    Mar 2009
    QLD
    Okay we have power everywhere except in the LP check fuse under the bonnet, when we stick a live wire in there we can turn the car over but there is no stsrt still. And fuel started spraying out from a hose under the bonnet.
  15. #15
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    fix the fuel leak first
    second the lp check is a relay youll need to replace the relay then hopefully your car will start
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  16. #16
    VN Commodore
    Mar 2009
    QLD
    vp executive 92
    Oct 2008
    newcastle
    lol failing that just swear at it some more, hope ya get to the bottom of it mate and please let us know
  1. Didn't Want To Start
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 03:14 PM
  2. Anyone know how to start car without the key?
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 04:58 PM
  3. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  4. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
  5. Where To Start
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 03:32 PM
