ok guys i put my urear ultra lows in my vn
i havnt put shorten shockers or adj p.rod
and the side the rleft hand side is sitting 4cm fkn higher then the right hand side
i driven it for about 4 hours since i done it n still hasnt leveled out
soo can comeone pleaseee tell me wtf is wrong ot wat iv done wrong when i put them in
iv checked them and they all sit on there rubbers right so i have no idea
please help
anyone had this ****ibng problem
should i change the left springs to the right n so on
could that be the reason
Most springs are marked left and right. Or it may not be sitting in the spring seats correctly.
I got told by a guy at king springs, that they are marked L/R cause the higher side goes on the drivers side, mine were only standard low though, so this may/may not apply to you..
They won't make any difference to ride height.
i remebr reading somewere tht u have they are marked left n right so im thinking of changing them
and were are they marked
yes they are marked left and right because the driver side is supposed to sit a little higher (so it comes even when the driver gets in).....
Depending on the brand, but most will have either RH or R and LH or L after the part number. Sometimes they have a D and P for Driver and Passenger.
ok cool but the driver sides sits with the wheel just under the gruad but the left side is like 4 cm above when i change the sides will the both sit with the wheel slightly under
well i dnt wanna waste my time changing them i might do it later on tonight but any one els had this problem
man, with standard shockers you could almost get the springs out without even removing the wheels.
Yeah, with ultralows or whatever it is you have, you should be able to get them in and out without dropping the shocks.![]()
The 1972 HQ Kingswood
yeahh i no tht but do u guys rekon i put them in wrong like does tht happen ahaha
cos ill kick myself if i did
well your options are
-Jack the car up and look
or
-Dont waste your time and live with it the way it is
Your choice![]()
ahaha yeah im gonna ajck it up this weekend when i spray my front bumper
if change the sides dnt fix it im gonna car bomb it
and BIG RICKY u got messager mate
i do man
d1_an_only_r1cky@hotmail.com
i just added you buddy are u online
nah i wont be online till later tonight/early tomorrow morning(2am+)![]()
i always thought lh sits higher becaue of the road camber.
does the car go down when you lean on it.
Maybe the shocks have bottomed out.
is the diff sitting on the rubber bumpers?
Is a wheel touching to body and holding it up?
are you gunna get the stuff to do it right and SAFE?
yeah it goes down when i lean on it n no the wheels not holding one end up
but i i still havnt tryed change the springs sides over to left to right cos i probl put them on the wrong sides so if tht dsnt level it out then i dnt no
OMFG i changed the springs sides and its the same sits the fucccking sameeee
i looked at part numbers on them n for anything els and there the same part number n everything no left or right on them
i dont no why its siting 2 inchs difrences
i checked its sitting all on its rubbers the right way so someone help me
