Results 1 to 8 of 8
Thread: help with code 42 Electronic Spark Timing Circuit
    None
    Aug 2005
    Adelaide, SA
    Default help with code 42 Electronic Spark Timing Circuit
    hey guys, sorry for probably dumb question, but where do i start looking for the code 42 Electronic Spark Timing Circuit so i can fix the problem? my vn s1 commodore v6 has the engine light come on and off every now and then and this is the code as well as oxy sensor, but car still runs fine.
    what can i fix to solve the Electronic Spark Timing Circuit?
    thanxs
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Sounds like its the Coil pack, change it over and see if its the problem get a mates one to borrow. also when you take the plug off have a look at the female connection and see if some are wide aprt this will cause the same problem i just cut off another connection and put one on.
    ~ VN POWER ~ Click the scales
    VP Exec
    Jun 2005
    Sounds like an ECM to me but that's just guessing without testing on the car. A search on here should bring up a few threads/posts on code 42 - it's pretty common.
    None
    Aug 2005
    Adelaide, SA
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    here you go.when the est code is displayed the timing will be locked at 10 degrees so its best to remedy the problem.most likely the DFI or the 2 EST control wires or the ecu.im helping someone else try to fix this problem right now and its not playing nice 4 DFI's and 3 ecu's and all the tests in that flow chart done still no luck.it is a flow chart for V8 but the v6 is much the same just the resistance of the dfi probably wont be the same as the V8 ignition module
    Attached Thumbnails Attached Thumbnails help with code 42 Electronic Spark Timing Circuit-img_0001.jpg   help with code 42 Electronic Spark Timing Circuit-img_0002.jpg
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    had the same problem till 2day, got a second hand coil pack and bam it was fixed
    vn calais 5 litre
    Oct 2010
    woodburn
    vn calais 5 litre
    Oct 2010
    woodburn
    i got spark but not enough to fire replaced coil plugs n leads still wont kick over
  1. code 14 coolant temperaure sensor circuit
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2008, 12:38 PM
  2. Electronic Spark Control
    By colmiller in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 11:30 AM
  3. Electronic Spark Control
    By colmiller in forum V6 Development And Modification
    Last Post: 08-12-2007, 11:32 AM
  4. Code 42 - Electronic Spark Timing Bypass Circuit fault (EST)
    By red phase down in forum Electrical Wiring / Questions
    Last Post: 19-08-2006, 06:29 PM
  5. Code 42 - Electronic Spark Timing Bypass Circuit fault (EST
    By red phase down in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 12:00 PM
