Results 1 to 5 of 5
Thread: vn horn (brass pin) problem
    omaz78's Avatar
    omaz78 is offline LIVERPOOL FOOTBALL CLUB
    EF FALCON FUTARA CLASSIC OLYMPIC
    Oct 2008
    Default vn horn (brass pin) problem
    i know this question has been asked b4
    my horn works only now and again, ive had a good look and worked out the brass pin behind the steering wheel has worn out,
    how do you get the plastic thing off the steering shaft tried for ages and couldnt get it off.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I think you are talking about the indicator bit. From memory there is a screw top anf bottom.
    The brass pin just pops out with just a little pressure.
    Or you can pack 2 small washers under all 3 screws holding the brass ring on. (this worked for my car)
    and 3 Dangerous non ABS VN's
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    All I did was smash an old festoon globe, get the glue out, and slip the end cap over the end of my horn contact pin, problem solved.
    VS l67 statesman
    Dec 2008
    There are two plastic clips you pry out (from memory) ,the reason that they can where out is the shaft maybe collasped a little bit as they are telescopic so they dont impale you in an acident ,
    omaz78's Avatar
    Oct 2008
    Cheers guys finally did it theres a horse shoe shape washer with 2 small holes in it got that off and pulled the spring out and it slipped straight out.
  1. Horn problem!
    By pauly5 in forum Electrical Wiring / Questions
    Last Post: 23-12-2008, 08:18 PM
  2. Horn Problem
    By ianf in forum Electrical Wiring / Questions
    Last Post: 07-07-2008, 03:27 PM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Horn problem in VP
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2005, 07:56 PM
