Results 1 to 6 of 6
Thread: VN FE2 V8 and V6 the same?
    1990 VN Executive
    Nov 2005
    Default VN FE2 V8 and V6 the same?
    Just wondering if front VN FE2 springs are the same wether its a V6 or V8. I always thought the front were different because of the extra weight in a V8.
    Cheers Dazz
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    I have FE2 V8 springs in my VPV6 with Monroe GT Gas shocks, no complaints here, front didn't lower a hell of a lot though.
    VE SV6, VE SSV
    Feb 2009
    ANyone got the spring rates for FE2 + standard suspension? Old mate reckons there is only 20lbs in it, main difference is lowered ride height.
    VP Executive R-spec
    Jan 2005
    V8 and V6 fronts are different part numbers, rear is the same. V8 springs in the front of a V6 would sit up pretty high. Not sure how many extra pounds they are but it's substantial. Stock will nearly put you on your roof cornering hard and FE2 will rattle your car to bits on country roads so there's quite a difference somewhere
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    if i remember right, v8 fe2's in a v6 will put you pretty much back upto stock height.....
    v6 fe2's in a v8 will bring you down to about superlows (im being rough here) lol
    1990 VN Executive
    Nov 2005
    Thanks Guys.
