Results 1 to 11 of 11
Thread: Help - VP cuts out when driving and then won't start for a number of hours
    VP Executive
    Mar 2009
    Question Help - VP cuts out when driving and then won't start for a number of hours
    I have a VP that I bought new - it has about 150k on the clock. It's generally in excellent condition and has been serviced regularly. Recently it's started cutting out when driving, and then usually won't start again for a number of hours. The mechanics I've taken it to for years are baffled. They replaced the ECU and for 6 weeks it performed perfectly until the trouble returned. They thought it might be the engine immobiliser and have by-passed it. The car performed perfectly for another six weeks and then the problem returned. They've now replaced the crank angle sensor but aren't convinced that's the problem.
    Any ideas? If the problem can't be solved I'm going to have to get another car. Any help appreciated!
    gdunkley84's Avatar
    gdunkley84 is offline I Have a Dent.
    2005 VZ SV6 6SPD (HBD)
    Jan 2005
    Hammond Park, WA, 6164
    The CAS was the problem with mine. Would drive along fine, then get hot and shutdown. After a little when it cooled a bit it would start fine again.
    2005 VZ SV6 6SPD - Holden By Design
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Next time it cuts out, pour some water on the CAS and try starting it again. If it starts, it is definitely the problem. But I see it has already been replaced....
    Visit my Facebook page
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Not all new CAS's are good quality. I'd also check the wires that go to the cas - give em a wriggle while running.
    Not starting for a while after it stalls - points to a heat related issue. And this is generally the CAS or DFI. How's the DFI unit?
    and 3 Dangerous non ABS VN's
    VN S1
    Jan 2008
    88GreenVN's Avatar
    Jun 2006
    Good point ^^^ when it stalls and refuses to start - is the fuel pump buzzing away at all?
    VP Executive
    Mar 2009
    Thanks for the help folks. Might be the CAS Not_An_Abba_Fan - that's the last thing that's been replaced so perhaps with a bit of luck that will have cured the problem. Re DFI unit 88GreenVN don't know what it's like. Mechanics seemed to think that a fault would knock out power to two cylinders - not the lot - or perhaps I'm getting mixed up with the coil pack. The odd thing is that when the problem occurs, the car won't restart for a long time. When it's happened late afternoon, it won't even start two or three hours later but always will by the next morning. Oddly enough as well, I'm sure that when it happens the car has always been decelerating and perhaps turning - coincidence perhaps. If it happens again 88GreenVN I'll listen for the full pump - good suggestion. Thanks again all.
    gdunkley84's Avatar
    Jan 2005
    Quote Originally Posted by gully View Post
    The DFI is the board that the coil packs themselves sit on. And if it goes all 3 packs would stop working.
    VP Executive
    Mar 2009
    Thanks gdunkley84. I'll check out with the mechanics whether they've replaced the coil packs. I suspect that the problem is non-heat related given the symptoms. I assume issues with the DFI aren't necessarily heat-related.
    VS SS
    Dec 2008
    i have same problem my vs ss will not start when driven for awhile and then fires and now starting to cut out when revs drop and wont restart for 30 mins , had fuel pump changed and no better.
    VT spac super6
    Nov 2008
    Riverton sa
    nearly everytime with electrical problems they either happen with high temps or cold temps..
    id say dfi straight out.. seen a few vn's with exactly that problem
  1. VT Engine cuts out while driving...
    By EnzyG in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:48 PM
  2. vl engine cuts out when driving. HELP IM STUCK
    By blue_vl in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 04:10 PM
  3. Car cut out while driving 50km and now wont start
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2005, 11:31 PM
  4. Engine cuts whilst driving.
    By BR377 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2005, 02:59 PM
  5. vs cuts out when driving and is hard to restart
    By spazgazz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2005, 01:29 PM
