Results 1 to 16 of 16
Thread: Main fuse blowing
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    Default Main fuse blowing
    this morning the main fuse blew (also think its known as the ignition fuse) in a mates VN so we replaced it tried to start the car and it blew again, what could be the cause of this?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    must be shorting out somewhere does it pop straight away or when you turn ignition to on or go to turn the engine over
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    when trying to start the car. Its been fine for years and started doing it this morning
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does the starter turn over? Could be the starter motor that has shit the tin.
    Visit my Facebook page
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The starter would be having too much current draw, replace it.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    youre not meaning hearing the fuel pump prime are you before you even turn the key pump could be dying
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    i dont know what im hearing, but their was something before the fuse blew. i think he going to replace the starter motor but we both short of $$$
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i highly doubt its the starter poping the fuse.we need more details if you turn the ignition to on 1 click before cranking when all the dash lights light up ready to start and the fuel pump primes does it blow or when you turn it the last click to wind it over after the pump has stopped wirring
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    its blows when trying to start the car. Can turn accessories on and its fine but on the last turn pop it goes
    в∞ѕтεכ √&
    Jul 2008
    NZ
    pull the cranking wire off the starter motor solinoid will be a little wire going onto a spade terminal and then try it.see if it pops then.
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    ok pulled the wire off and turned the key and the fuse didnt pop
    put the wire back on and fuse didnt pop and car started, turned car off tried to start again and didnt start and fuse didnt pop.
    fiddle with the wire again and tried and car started.
    i have to fiddle with the wire everytime to start the car.
    what could fix this?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    clean the terminal up good for a start.is it auto could be the inhibitor switch in the gear lever as well try it in neutral.
  15. #15
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    yeah trying to clean it atm and yeah its auto will try it in neutral next
  16. #16
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    ok problem seems to be fixed now, degreased it all and cleaned it up, connected it all back up and it now starts alot faster and smoother and seems to be a little better running.
    also thanks for all help
  1. vs main fuse box diagram
    By OAZ240 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2008, 01:26 PM
  2. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  3. main fuse keeps blowing up
    By vnv690 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 11:11 PM
  4. HELP main fuse blowing
    By danny1987 in forum Electrical Wiring / Questions
    Last Post: 16-02-2006, 09:10 PM
  5. Blown the main fuse :(
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 09:50 PM
