Results 1 to 16 of 16
Thread: starter ???????????
    vp executive 92
    Oct 2008
    newcastle
    Default starter ???????????
    hey guys and gals got a quick question for yas will a vp starter fit on a vr???
    the gf brought a vr and the ****er wont start i have tried charging the battery no good tried useing mine (from a vp less than three month old) the vr has power just wont kick over so i was gunna swap starter and see if that helps
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Hit the solenoid with a hammer or something heavy and see if it starts then. As far as I know they are the same. The VN series 1 was different, then the VS changed again.
    Visit my Facebook page
    vp executive 92
    Oct 2008
    newcastle
    ok i jumped it ran it for like an hour turned her of then nothing but ticking after a piss weak attempt at starting
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like the battery then.
    vp executive 92
    Oct 2008
    newcastle
    aint the battery i put a brand spankin new one in same problem grrrrrrrrrrrrrrr
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by lukieboy View Post
    could be the alternator not charging the battery. or did you mean you put a new battery in and the problem happened right away, before any charging.
    is it auto or manual btw?
    vp executive 92
    Oct 2008
    newcastle
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Have you checked the connections on the starter and the battery, make sure they are tight.
    vp executive 92
    Oct 2008
    newcastle
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    might be the inhibitor switch on the gear lever try in neutral instead of park
    vp executive 92
    Oct 2008
    newcastle
    yeah tried that no my car is doing it (vn engine s1)
    will a vp fit this one???????
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    vp executive 92
    Oct 2008
    newcastle
    how do i do that???
    i didnt think of the efi relay on the vr due to the fact i can get the damn thing started (with jump pack same as vn)
    в∞ѕтεכ √&
    Jul 2008
    NZ
    so you connect jumper pack leads and it cranks ide say you srnt getting a good contact on the battery posts are you putting the neg of the jump pack on the battery or straight on the block if putting it on the block ide say earth from battery isnt connecting well.are either of the battery terminals hot after trying to crank it without the jumper pack
  15. #15
    vp executive 92
    Oct 2008
    newcastle
    nope the battery terminals are fine ive checked and rechecked all eath leads and connections all good
  16. #16
    vp executive 92
    Oct 2008
    newcastle
    hahahaha im an idiot fuse blown in engine bay for the fuel pump need to replace that relay thanx again for all ya help guys
  1. Vt Starter on old 308
    By Dezza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-12-2008, 05:23 AM
  2. Starter motor
    By HAZZA-VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2008, 08:38 AM
  3. starter
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 10:51 PM
  4. VG ute starter motor
    By oldsurfiepete1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 12:58 PM
  5. Is this my starter motor?
    By dave.b in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-09-2006, 08:42 PM
