Results 1 to 17 of 17
Thread: new steering wheel
    Vp commodore 3.8ltr v6
    Feb 2009
    Default new steering wheel
    can i easily take my old steering wheel of at home with basic tools and put on a new one? cos frankly the vn steering wheel is horrible
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    you'll need a wheel lifter (should have them at super cheap or equivilent) and if your putting a new aftermarket wheel on you'll need a boss kit for a vn
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by jakewaze View Post
    No you won't.
    After you take the horn cover off and remove the nut you can wiggle the wheel off. Theres a technique to it, but most people try to use force which isn't the way.
    A steering wheel puller is the easiest way, but you do not NEED one. Probably are worth the money though as you'll end up removing more than one steering wheel in your lifetime if you're into cars.
    VT Calais 3.8
    Nov 2008
    I replaced the one on my VP when it's rubber was borked. I found the easiest way is to loosen the bolt but not all the way off and then grab the top of the wheel with your hands and pull against the bottom with you knees (your legs are really strong by the way), should give way easily. Just make sure you don't take the bolt all the way off or you may accidentally smack yourself in the face when it comes loose.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Wiggling the wheel from side to side is so much more effective. Short, sharp pulls, and it will come out within a minute.
    The 1972 HQ Kingswood
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    i took mine off on the weekend using 2 bolts and ans a cog from a bicycle and a shifter LOL
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by Morton View Post
    What the man said
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    My VN wheel was extremely hard to get off. Tried wiggling it, pulling it, quick taps with a hammer, nothing. Then my harmonic balance puller kit arrived. Thought why not, same thing as a wheel puller.
    Let me put it this way, I tried with a large shifter to a point I couldnt turn it anymore before rounding the bolt head. I got so frustrated with the bloody thing and got a socket + breaker bar. I thought the bolts would strip if I tried any harder but anger made me keep going then finally *CRACK* as the wheel crashed into the nut (make sure you leave the nut on the steering shaft as you pull it off!).
    I highly recommend buying a puller. Because if its like mine, no way in hell are you getting it off by hand.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    My stock wheel came off with a little bit of elbow grease, but my boss kit is definitely happy where it is, it isn't going anywhere, at least without some kind of puller and a socket, heh.
    Feb 2009
    Smile
    thanks for the advices guys, i will try and get the wheel of without the wheel puller with my old man as soon as the funds alow me to buy a new wheel (on extreemly tight budget for the next year) hoping to score one at a wrecker. if all else fails ill just give it to a mechanic.
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Wheel puller, you won't regret it, especially if the wheel is the original and hasn't been removed.
    Vp series 2
    Jun 2008
    wheel and boss kit on special at repco this week $119 wood grain only.
    steering wheel puller $10-20.
    SO worth it.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    shouldnt take more than 20 secs after the wheel nut comes off. palms flat facing you at 9'oclock and 3'oclock and just bang back and forth 9 3 9 3 . a 10 year old can do it....
    dont sweat the petty... pet the sweaty...
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by centy View Post
    SO worth it.
    Better off sticking with legal steering wheels. Worth spending the extra.
  15. #15
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    No matter what I did with mine it wouldn't budge. I used a puller and it worked straight away. Both cars I've had to use a puller.
  16. #16
    VP Executive R-spec
    Jan 2005
    Both mine came off in about 5 seconds, easy as. just get hardcore, bash them around a bit side to side to break the loctite like all the boys said. Leave the nut half done up to save yourself a wheel in the face and it should be fine
  17. #17
    Aug 2008
    went to the wreckers one time with my mate to get him a wheel, he was like wheres your wheel puller... i was like your looking at em (two middle fingers)
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Steering Wheel
    By Timmos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2008, 01:44 AM
  3. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  4. Steering Wheel Fix
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2006, 11:34 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
