Results 1 to 15 of 15
Thread: HELP caliper->hub bolts ridiculously tight
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default HELP caliper->hub bolts ridiculously tight
    all 4 wheels need new banjo bolts, so while i'm doing brake works i thought i'd take the front calipers off to respray them.
    i've only taken the rear ones off before. but when i got new front discs and pads they must have done them up with a rattle gun or something cause they're stupidly tight. for a second i thought it might be reverse thread, but i didn't remember the rears being reverse threaded
    tried a bar on the end of my socket wrench, hitting the spanner with a hammer, nothings shifting it.
    vb sle
    Jan 2009
    adelaide
    got any penatrine or wd40 give that ago then try they are some tight suckers
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    take that whole caliper mounting piece off and put it in a vice give that a go.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by leigh 7005 View Post
    tried wd40, still wouldn't budge
    Quote Originally Posted by ScoHar View Post
    you mean like disconnect the tie rods etc? if i had a vice i'd maybe give it a shot but unfortunately not.
    might take it back to the place that put on the discs and pads and tell them they rattle gunned it too tight.
    i know it's a safety thing but i didn't think the torque necessary on them was more than a person could do manually
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I've never had them that tight that they won't undo with a bit of help. The ratchet or breaker bar you are using isn't against anything is it?
    Let it hang down and use your foot to put pressure on it.
    Visit my Facebook page
    Vp series 2
    Jun 2008
    you mean the 3/4 dolts on the back of the caliper bracket?
    Those suckers are suposed to be tight, long bar and foot is the choice.
    Don't worry they are grade 10 and super strong.
    Why do you need 4 banjo bolts? What have you done to stuff all four of them?
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by centy View Post
    when put in new rears i noticed one was warped by being too overtightened. the hole through the side was less and O than it was an O, then when i put the bolts in, one snapped. i had another on hand so i was lucky. but i got a new set and been mening to do em for a while. figured while it's being done i can paint em properly too. right now i've got shiny red rears and crappy navy fronts with rusted hubs.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    they actually have a very low torque rating, rattle gun is just stupid if true.
    All i can suggest is put a breaker bar on and "rattle" the shit out of it to get it off.
    There has been no bolt on the car that i haven't been able to get off with blunt force and breaker bars.
    Try to snap the thread lock, ie, immitate a rattle gun with a lot of force in short bursts.
    aZk.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by azkwazere View Post
    Agreed, heres the VT specs from the manual:
    Front brake caliper anchor bolt 80 - 90 Nm, plus
    40° - 50O turn angle
    Rear brake caliper anchor plate bolt 70 - 100
    In perspective a wheelnut should be 110-140nm.
    I just use a small breaker ball and my foot. If its really tight get a large breaker bar and a bigger foot lol.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    May 2005
    .....SE Burbs
    A bash mallet or panel beaters dolly on a breaker bar should be sufficient.
    aZk.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    goddamn, just got it off, i had to buy a 380mm breaker bar (the tube wrench on the end of the socket didn't do it) then put the tube wrench on the end of that, even with that it was hard going.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Want to buy a weight set?
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    already got one thanks. as i said before i think they used a rattle gun to do them up
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sometimes people do bolts up to that last setting on the torque wrench....."ridiculously ****ing tight"
  15. #15
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    yea most bolts are done up F.T
  1. Ridiculously low speed limits
    By MikesCalais in forum The Pub
    Last Post: 21-01-2009, 05:16 PM
  2. Anyone change Caliper Bolts ???
    By vxcalais_01 in forum General Discussion
    Last Post: 14-01-2009, 08:01 PM
  3. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  4. help..Bolts mega tight!!!
    By Troy5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2008, 08:52 PM
  5. caliper bolts
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2008, 08:44 PM
