Results 1 to 13 of 13
Thread: fly wheel???
    VP V6 S2
    Nov 2007
    Sydney, NSW
    Default fly wheel???
    Hey guys just did a manual conversion on my VP and am experiencing a slight vibration when the engine gets to about 2000 rpm +.
    This happens when in gear and out of gear. stationary and moving.
    So i have cut down the options to a flywheel being un-balanced or the clutch components being un balanced.
    What do you think?
    any other options i could be missing?
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Chances are the flywheel does indeed need a balance, it's kind of natural to feel more vibration from a V6 converted to manual over auto though... How much vibration are we talking?
    VP V6 S2
    Nov 2007
    Sydney, NSW
    Yeah i have heard of that before, the auto to manual vibration thing, but the vibration is quiet strong. definitely not from the conversion to manual side of things. only comes in at 2000+ and yeah you can feel it lol.
    No how much that would cost to get done roughly?
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    If you take the flywheel out, probably just a couple of hours labour at a machine shop. How are your engine mounts/gearbox mount/harmonic balancer? When you fitted the manual, did you check it wasn't fouling against the transmission tunnel?
    VP V6 S2
    Nov 2007
    Sydney, NSW
    Yeah engine mounts are brand new and so is the gear box mount got them changed like a month ago.
    i'll have a look at the harmonic balancer pretty sure she's sweet though.
    Yeah i got the fly wheel machined before i did the conversion. I thought that would have balanced it up?
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    I remember a mate doing a gearbox swap in his VL turbo, when he put the new box in, he forgot the spacers that go between the gearbox cross member and the chassis of the car... I need confirmation to be sure if these still exist in the VP though... It really caused a nasty vibration similar to what you're describing (lack of spacers meant the gearbox was hard against the trans tunnel).
    As for machining a flywheel, that's a totally separate process to balancing one.
    VP V6 S2
    Nov 2007
    Sydney, NSW
    Alright well sounds like the balancing could be the issue.
    Box is definitely not touching the tunnel so that's a good thing. i don't know about the spacers though. Never heard of them before on the VP but again im not to sure.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Is it a dual mass flywheel? Often you can't machine those.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Mar 2008
    did you replace the spiggot bush or bearing
    as said the flywheel shouldnt need balancing as im pretty sure those models are balanced internally
    double check that your engine bolts are tight , maybe the harmonic balancer has thrown out a bit of rubber in it and running out of balance
    or maybe your flywheel needed machining
    did you change your tailshaft at all , maybe the uni's are buggered or its out of balance
    VP V6 S2
    Nov 2007
    Sydney, NSW
    Yeah i replaced the spiggot bush put a new one in.
    I got the fly wheel machined. As for it being a dual mass flywheel not sure exactly what that is so i cant answer that but i got it machined if that means that it isn't one?
    I thought that it was the tail shaft at first but when i was stopped, put it in neutral and revved it, it still vibrated and since the tail shaft wasn't moving thought id cancel that out.
    so next is for me to check the harmonic balancer.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you got the manual spigot bush?
    is your clutch aligned properly?
    Balancing isnt really necessary i have done a manual conversion without balancing and theres no excessive vibrations compared to normal car type one
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Vp series 2
    Jun 2008
    spigot bush and how tight did you do the flywheel and what bolts did you use.
    VP V6 S2
    Nov 2007
    Sydney, NSW
    Yeah i put a new spigot bush in and the bolts wer new fly wheel bolts from boyded.
  1. Which Wheel ?
    By guss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2011, 06:43 PM
  2. wheel set.
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2006, 09:16 PM
  3. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
  4. fly wheel
    By VH camping in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2005, 07:04 PM
  5. 308 Fly Wheel
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 09:40 PM
