Results 1 to 9 of 9
Thread: VN V6 Manual Clutch Fork Weight
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Question VN V6 Manual Clutch Fork Weight
    When i pulled the gearbox out to replace the clutch, i seen on the clutch fork was a big weight, i pressume its for ballancing perposes, anyway i dont like weight in my car so it had to go, so out with the angle grinder . when i put it all back together my clutch cable is making a squeeking noise when i clutch in, but its only here and there, i dont know if its from this problem or if the clutch cable is just streched and seen better days,
    Sooo can someone tell me why the put that big weight there? i seen on a Vn V8 clutch fork it didnt have one, so why should i
    ~ VN POWER ~ Click the scales
    Morton's Avatar
    Fairstar the Funship
    May 2006
    That's interesting - did you take any pics? I've never seen a V6 clutch fork, only done a few V8 conversions hahaha
    It could also be to do with strength. Clutch forks tend to bend sometimes, so it's good for them to have as much metal as possible
    Get a billet flywheel if you can. They weigh a bit less than factory ones, and give you less rotating mass which equals more free revving
    The 1972 HQ Kingswood
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    mine has one. im pretty sure its there to stop the clutch fork from rattling
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VP Executive R-spec
    Jan 2005
    The fork is identical on the V8 and the V6 apart from the weight welded on the V6 one why exactly it's there I have no idea . I agree with your theory tho, if it's not on the V8 version and it's heavy get rid of it :P
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its a vibration dampner if i remember rightly should be no biggy not having it might feel some pulsing through the pedal but meh saved a few grams LOL
    vn calais,vk calais padock basher
    Mar 2005
    a few grams lol it weighs like 3 kg
    vn calais,adjustable strut tops,whiteline front and rear adjustble sway bars,full front to rear bush kit, strut brace,18" rims, vn v8 lsd,2 1/2" cat back exhaust custom made, vz hsv glass body kit,sv5000 rear wing + deleted stop light,rebuilt motor, oversized throttle boddy custom pod filter inclosure, ,stage 3 chip, ,1 inch master cylinder and double brake booster,custom bonnet.
    future mods, currently doing a respray,, retrim and turbo conversion,
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Its a vibration balancer... if your clutch fork rubbers wear down, its gonna rattle like a bitch!
    aZk.
    VN S1
    Jan 2008
    What happens if he doesnt have the rubbers either eheheh, weight stripping the vp to race specs has made him the jenny craig of jc.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I have stripped alot of weight out of the VN she was on a diet for awhile.
    I dont have clutch fork rubbers couldnt get any unless i bought a clutch kit, but yes it is a heavy thing and is all gone now and even though i done have the rubbers for the fork it doesnt rattle and didnt make any difference in performance or anything a good way of saving a couple KGs.
    Needwork2, also mention about the weight in the bottom of the gearbox and ditching that, but not to sure on that one, i was thinking about it when the gearbox was out last, but who knows if there are some good answers or comments about ditching it, next clutch i put in the weight will be ditched aswell, the things you do to shed some KGs
  1. VS S1 Clutch Fork !!
    By surrealistic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2008, 05:51 AM
  2. Vn Clutch Fork ????
    By wayne_140 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2008, 06:03 PM
  3. Where to buy a clutch fork these days?
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2008, 08:09 PM
  4. Broken Clutch Fork
    By RufusŪ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2005, 12:49 PM
  5. clutch fork
    By wombat1961 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2005, 03:57 PM
