hi my rigth back wheel was making a funny noise today when driving. when i got home i took off the hub cap and found that 1 of my wheel stud had broken off. so i decided to take the wheel off to look at the hub in doing so i snapped off antoher stud. 2 of the studs are loose and turn. does anyone know how to get the hub off the back and replae the studs. cheers!
Wow, that's bad. You can access the bolts that hold the hub onto the axle through a gap in the brake drum. You'll see them when you look for them![]()
The 1972 HQ Kingswood
Smack 'em thru and put in new ones. You don't need to take the hub off - just slide the disk off the back and pull apart the handbrake shoes. No biggee. If 2 were broken I'd be inclined to change them all.
Reaper
Yeah they sound pretty rooted![]()
