Results 1 to 3 of 3
Thread: adjusting door latches, is there a trick to it?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default adjusting door latches, is there a trick to it?
    for a while my drivers door seems to have had needed a bit of a throw to get it to shut and it just makes the car looks like a ghetto ride.
    i had a crack at adjusting the catch with a torx head but it always seems to foul, even when it doesn't scrape the receiving bit on the door, it still doesn't close smoothly. the door doesn't have any up/down movement when its open so i don't think it's the pins. what else should i check for?
    also the passenger side has a slight bit of force needed, but nothing i'm concerned with. it's just the drivers side.
    vt s s1
    Mar 2009
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    there's a feeling when the catch scrapes the top or bottom of the receiving bit, apart from that the only noise is a bit of a squeek of the sealing rubber at the front near the pins
  1. Help me to trick my ECU..
    By Zipster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2009, 04:27 PM
  2. Adjusting drivers door?
    By mimosa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2008, 01:46 PM
  3. Adjusting Door Latches on VYII
    By Supercharged VY II Calais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-09-2008, 07:02 PM
  4. trick audio
    By VRMan in forum Car Audio
    Last Post: 26-09-2007, 07:35 PM
  5. Need advice on sticking latches
    By jason_vs in forum General
    Last Post: 28-05-2006, 07:12 PM
