Results 1 to 5 of 5
Thread: BAD vibration underload
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Unhappy BAD vibration underload
    Hey guys,
    Was driving to TAFE this morning and suddenly had my VN start vibrating really badly. Mostly in 4th gear and when applying load to the engine and worse at around 80km/h. Also vibrates badly in reverse and when accelerating from a stand still. Vibration is throughout the entire car and is really bad underload. Replaced harmonic balancer so thats not the problem. Really need the car for TAFE so I can continue study so I'd like to get it fixed ASAP. Any help would be really appreciated.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by 89berlina View Post
    Hey guys,
    Most likely 1 of 2 things.
    Centre bearing or the gearbox. If you are getting ant sort of noice - screaching - the box.
    Look under the car and see if there is any grease sprayed oround the centre bearing
    and 3 Dangerous non ABS VN's
    vb sle
    Jan 2009
    adelaide
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Engine mounts, gearbox mount, centre bearing, unis, and diff allignment (condition of rubber bushes) all contribute to this.
    1989 VN Berlina
    Jul 2008
    Quote Originally Posted by leigh 7005 View Post
    also check your engine mounts
    Quote Originally Posted by 88GreenVN View Post
    Quote Originally Posted by camstatic View Post
    Hey guys appreciate the help. Fixed the problem. Ended up being a blocked injector. Really need to find myself a 68 litre fuel tank because the one I have now is corroding and spewing out muck into my fuel system. Injectors were brand new and somehow one of them got blocked meaning the car was running on five cylinders hence the vibration. Anyone know of someone in QLD with a spare tank thats still good?
  1. VS Clubsport bad Miss underload
    By richo7502000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 11:04 AM
  2. Vibration
    By lilzen96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 02:19 PM
  3. VZ Vibration
    By Clinster in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-08-2006, 07:55 PM
  4. vibration
    By remmie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 06:29 PM
  5. VR ll vibs underload
    By Dave R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2004, 05:49 PM
