Results 1 to 7 of 7
Thread: engines?
    sydd131 is offline Banned
    Vn Calais
    Oct 2008
    Default engines?
    heyyy, i've currently got a vn calais, was gonna sell it cause of rust under windscreen, but its not gonna cost much so im keeping it. Annyywayys, engine has 290,000 on it, think its gonna die soon, i got quoted $3500 with a reco engine and to have it installed, i was like whoa, thats a bit over the top, but i've heard theres another joint nearby that does em for $1500, but i've found reco performance engines for just under 3,500. is this worth getting:
    1 X PERFORMANCE BUILT RECONDITIONED LONG ENGINE .
    BLOCK CHEMICALLY CLEANED,DECKED,NEW CAM BEARINGS INSTALLED.
    REBORED AND HONED TO PERFORMANCE TOLERANCES.
    CRANK GROUND AND LINISHED.
    NEW WELSH PLUGS,
    HEADS FULLY RECONDITIONED ,NEW VALVES ,BRONZE GUIDES,3 ANGLE VALVE GRIND, BACK CUT VALVES,BOWL PORTED AND FLOWED.
    SUPPY AND FIT NEW STAGE 2 CAM AND LIFTERS.
    LONG ENGINE PAINTED AND FULLY ASSEMBLED
    X SET ACL PERFORMANCE PISTONS AND RINGS.9.5 :1 COMP
    1 X SET ACL MAIN AND CONROD BEARINGS.
    1 x Clive Roller 212 @50 Hydraulic Cam 2500 -6000 rpm.
    1 X SET OF PERFORMANCE VALVE SPRINGS
    1x Performance 70 mm throttle body c/o.
    1x Performance chip to suit cam listed c/o.
    1x Rollmaster Red timing chain and gears SINGLE ROW
    12 x Hydraulic lifters( NEW ! NOT RECO)
    1 x FULL GASKET SET
    would that be worth getting for $3290? if i keep this car i wanna get the engine rather good as i'll be on my p's soon which means easternats/summernats. any opinions please?
    Vn Calais
    Oct 2008
    vr executive
    Oct 2008
    tassie
    drop a 5litre in it buy a $h1t bodied but good motor vn ss and put the motor out of that in it it wud b sweet
    Vp series 2
    Jun 2008
    VP Executive R-spec
    Jan 2005
    Agree, buy a 5litre that's clean on the insides, much much cheaper way to get the power.
    Oh I see you are on restricted P's soon, in that case just stick a stock motor in it when this one breaks and keep your money for later then do as above ^
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I'll second those opinions. For the money you'll spend on that "performance" motor, you won't get much performance. Money badly spent if you ask me.
    The 1972 HQ Kingswood
  7. Default
    i've seen them on ebay, just searched up your specific one - he estimates 155kw at the flywheel (probably estimates more than it really is as well). for $3,300, you can get A LOT more power. you can easily get a wrecked 5ltr, drop it in, do a few mods (CAI, chip, exhaust) and if you're lucky be pushing 200fwkw... all for less than $3,300, plus you have a nice car outside with lots of spare parts to either keep, or wreck yourself on ebay and start making money back!
    Quote Originally Posted by zai View Post
    I am not sutpid
  1. engines
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 08:23 AM
  2. New Engines!!
    By Fast_VR_Boy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2007, 07:25 AM
  3. Engines
    By TRuchaldo in forum General
    Last Post: 12-02-2007, 06:20 PM
  4. VN-VP engines
    By ***In The Build*** in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 08:29 PM
  5. VR engines??
    By comblydore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2005, 12:33 PM
