Results 1 to 4 of 4
Thread: Bad Brakes
    VG Exec
    Oct 2007
    Default Bad Brakes
    G'day all,
    been having troubles with the brakes on my ute,
    the problem is that the pedal is really soft and touchy,
    only works half the stroke
    Has a full hard pedal when engine is not running,
    as soon as the engine is fired pedal is not good.
    parts replaced so far
    brake booster
    master cylinder
    proportioning valve
    new rotors and pad all around
    calipers have had new seals installed in front and new calipers in rear.
    Any thoughts or suggestion's???????
    VG commy
    rb25det and running gear
    shaved lines, turismo blue
    VP Exec
    Mar 2009
    Melbourne, bayswater
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Since you have replaced nearly everything. As suggested above, the brakes may need a proper bleeding. Do you have ABS?, if so you may need someone with a tech2 so the ABS actuators can be turned on to allow correct bleeding process.
    Are you loosing any brake fluid?, do you have a damaged brake hose that may be swelling under pressure?
    muttley383
    VG Exec
    Oct 2007
    Yeah bleed the brakes many times Reverse flush ie pushing fluid in,
    and convential way. not losing any fluid and no vechile does not have abs,
    Cant say 100% that the lines are all good but i have cheched them very closely and they appear normal. Thanks
    VG commy
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. Brakes ?
    By NVE_069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2006, 12:52 PM
  3. CSC Brakes
    By topperge in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-07-2006, 04:49 AM
  4. brakes
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2006, 10:00 PM
  5. vk/vl brakes
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2006, 04:55 PM
