im working on a turbo conversion for my v6, now what a/r is ideal on the compressior and exhaust housing?
im making tuned length manafold for it from 2 inch pipe.
im wanting to keep the aircon but allso want to have a 3 inch dump pipe can it be done?
i allready have a turbo its a garret to4e now i know the front housing will be small but is the exhaust to small its a/r is 100
The oil pickup for the turbo will come from the remote oil filter im fitting to gain extra room, allready got ev1 injectors and have an adjustable fuel reg which i mite change out for a riserate reg.
only going to run 5psi to start with to conserve the motor as i have quite a rep for destroying v6 motors.
going to run a plumback bov which means running an airbox, question is will the bov still be loud as im wanting to keep it stealthy atm.
tim
vn calais,adjustable strut tops,whiteline front and rear adjustble sway bars,full front to rear bush kit, strut brace,18" rims, vn v8 lsd,2 1/2" cat back exhaust custom made, vz hsv glass body kit,sv5000 rear wing + deleted stop light,rebuilt motor, oversized throttle boddy custom pod filter inclosure, ,stage 3 chip, ,1 inch master cylinder and double brake booster,custom bonnet.
future mods, currently doing a respray,, retrim and turbo conversion,
i have no idea man, but please post some pic's when your done.
Hi mate, You will only need 2inch NB pipe for the crossover pipe, it will be to big for the runners, for the turbo you want a exhaust housing a/r of about 0.64-0.84 unless you have a ball bearing turbo inwhich case a 1.06 housing seems to spin up fast enough, You are going to need atleast 30pound injectors to keep the fuel up to it and do it right and tune it to suit, dont just put a rising rate regulator and bigger injectors on it. Do some research on this forum with the search button up the top, every aspect of turbocharging a v6 has been covered.
Matt
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
wanna run stealthy, paint the cooler and all visible piping black but it will be possible to hear the pump back pov, so when required just keep it off boost and it should be fine.
You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
ok my to4e has a 100 rear housing is that going to be to big? i know the front housing will be to small so i will be upgrading that.
what size should i make the primaries?
What size cooler, i mainly want to get all the pipe work out of the way so the car wont get scratched up after its painted.
and yes i have look through the search forum and havnt found much to help me at all.
and 5 psi will be ok for a stock motor wont it? I dont want to kill the motor on 8 psi, thats the next motor that im spending around 5-6k on.
tim
1 5/8 inch for the primarys is big enough i think and if the turbo isn't ball bearing then i think 1.00 is too big. I put a t70 with a 1.06 rear on my setup and it wouldn't spool untill about 4000rpm... Cooler i have a 600 x 300 and it fits with heaps of clearance.
all the info you need is here, i built my whole setup using the info from here.
Matt
- Lou Holtz
how thick was the cooler 76mm?
well i gues i can allways get a different turbo later down the track if its to smal or big or could allways stroke it lol.
yeah about 3inchs thick.
Matt
- Lou Holtz
allrighty, cooler will be bought next week then getting the pipeing done at a1 exhaust out of stainless 3 inch pipe and then its up to me to make the manafolds
thanks tim
check out clints wagon saves making more than one manifold when done like this and has room for a good size dump from the turbo delcohacking.net • View topic - Turbo VN V6
ok delta fin intercooler on its way, bov bought, working on the oil feed and drain lines as we speak.
things are comming along really really fast.
.thanks delco ille have a look now
tim.
where has everyone run there pipe out of the cooler, my car is to low to do a 3 inch under the radiator
intercooling raptor blown vy v6 check out post #5 dont know how he did the other side though
ok upgrading the turbo to a ball bearing/duel ball bearing turbo. im looking at only using garrets turbo
Garrett Ball Bearing Units
what turbo should i be looking at buying there?
tim
anyone got an idea?
On page 2 the is garret gt3582bb Up to weather you want to go with the 1.06 or .82 rear housing.
Matt
- Lou Holtz
what would be suited to a stage 5 sre motor. HOLDEN V6 STAGE 5 COMMODORE 215KW SRE ENGINE SUIT VN-VT - eBay Engine Modifications, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 16-Apr-09 10:27:44 AEST)
tim
would the .82 housing be a restriction?
and looking at have 5psi at 2800rpm, what ar would be better for that?
tim
anyone have an idea?
