Results 1 to 9 of 9
Thread: Strange Electrical Problem?
    VN S
    Apr 2009
    Default Strange Electrical Problem?
    Hi there,
    I'm really hoping one of you can help me with this. I have a series 1 V6 VN commodore manual (probably not relevant). The car drives fine most of the time, but every now and then (once or twice a day) it will suddenly cut out on me - regardless of whether revs are low or high. When I try to restart it, it runs for about 5 seconds then stops again (the battery light will be on while it does this). After 30 seconds or so, if I start the car and the battery light has gone out then I know it has fixed itself (it always starts in the end). The problem can happen when the engine is hot or cold. Additionally, the battery light comes on from time to time during normal driving. This has been going on for 6 months. I know I should get a better car, but I am too stuborn damn-it.
    I ran the system diagnostic test and it came back with code 12 (no fault).
    what I've changed to try and solve the problem:
    * Coil pack
    * Alternator
    * Battery
    * ECU
    If anyone has any information then it would be bloody awesome if you could post it here
    Cheers.
    VS Commodore Omega
    Apr 2005
    Does the car fail to start just after the stalling or does it get back up straight away? If not then all I can think of is the crank angle sensor; next time it happens try pouring some cool water (not the aftershave) on it and see what happens - they're about $50 from repco
    EDIT: Just found this, may help: http://www.phoenixmechanical.com.au/...lectrical.html
    VN S
    Apr 2009
    Hi VS Omega, thanks for the quick reply. The car always re-starts immediately, but might only run for 5 seconds before stopping again (as mentioned above). My feeling is that it is not the CAS for the following reasons:
    * The ECU test reports no fault
    * The problem can sometimes occur before the engine is even warm
    * After cutting out the car will only continue running once the battery light has gone out
    I am probably going to change the CAS anyway just in case, but if anyone has any other suggestions then please let me know.
    Ta.
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    What's the condition of your engine earth like? After checking that out, I'd be inclined to inspect the alternator charge, and sensor wires that go straight to the positive battery terminal. Definitely sounds like a loose connection of some type.
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    I agree with a loose connection or bad earth, The battery light isn't ment to come on unless there is a problem.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Quote Originally Posted by jez111 View Post
    Hi there,
    * Coil pack
    * Alternator
    * Battery
    * ECU
    Cheers.
    Sounds like your coil pack is on the way out
    VN S
    Apr 2009
    cool thanks for the info guys. I will go over those points to make sure there are no loose connections in the wiring or earthing. Is not the coil pack because I replaced it since the problem first occurred (mentioned above)
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    One other thing - is the fuel pump buzzing away every time when your restart the car?
    and 3 Dangerous non ABS VN's
    VN S
    Apr 2009
    funny thing - the problem hasn't happened since posting. Thanks 88GreenVN, that is a bloody good suggestion. I will post back when I get to the bottom of it. Any other suggestions, please post!
  1. VN electrical problem - plz help!
    By wezzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2011, 08:29 PM
  2. electrical problem?
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2009, 04:42 PM
  3. Serious Electrical Problem!
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 06:09 PM
  4. strange electrical problem?
    By uneekwahn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 05:55 PM
  5. Strange, strange problem.
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:26 AM
