Results 1 to 12 of 12
Thread: Hot Motor
    89 VN
    Feb 2009
    Default Hot Motor
    I have something that may later become a problem to ask you guys.
    The motor on my car runs very hot now it runs fine and everything but when you lift the bonnet after even only like 1min of running time it's frying and you can't work on it until about 10mins or so.
    May i need to flush out my radiator or get a new one?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    That sounds like a water pump issue.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    VP Exec
    Mar 2009
    Melbourne, bayswater
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Radiator and Fan wouldn't be playing a part in it if it's overheating in the first minute.
    The three things I can think of are:
    1)Waterpump
    2)Thermostat
    3)No water IN the cooling system.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    89 VN
    Feb 2009
    Jun 2006
    My cars waterpump has just shit itself ... got the wobble and leaking coolant ..
    waterpump costs like $90 and say $80 for labor ...
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Yea could be a few things, might not be holding pressure, thermostat, fan, waterpump may be even a headgasket. Diagnose the problem first before replacing things as you will just spend more money.
    Ild get a mechanic to do a pressure test on your system, cost like $30 from memory.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    blocked CAT
    89 VN
    Feb 2009
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if it gets hot in less than a minute its most likely more than the thermostat.whats getting hot everything or just the manifolds getting hot
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Well a coolant flush is fairly simple, just need a hose and some coolant. But make sure you be careful were you drain it if you dump it just anywhere you can get a nice stinkin' fine from the EPA.
  1. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  2. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. VT fan motor for AC
    By danx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2007, 08:58 PM
  5. VN V8 Motor
    By griffindore in forum Parts And Other Items For Sale
    Last Post: 11-09-2006, 10:11 PM
