Results 1 to 5 of 5
Thread: Code 42,
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Default Code 42,
    Hi
    Since i bought my S1 vn a few months ago the engine light has came on and off throughout each drive. When the engine light is off the car runs REALLY smooth, has plenty of power etc, when the engine light is on it lacks power (probally about 20%less), idles rough and gear changes are harsher and at a higher rpm.
    Any way this is a typical drive in the morning. Start the car in the morning and drive to work (5mins) with the engine light off , thats fine, a smooth drive. After work start it up, engine light is always on after work, it lacks power etc etc.
    also temperature doesn't seem to affect it. Sometimes when i am driving the car will surge and the engine light will either switch on or off. If the engine light is off and it idles for too long (about 60seconds) at the lights it will usually stall, start it back up and the engine light is on.
    Its really confusing me because it will always start straight back up but the engine light will either come on or off.
    I have no other parts to use so I would prefer to know what it is b4 buying anything.
    Also it is coming up with code 42.
    I just had it serviced at automasters (major service) and they just said that it requires further investigation $$$$$
    Thanks, sorry if it is a bit confusing lol
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Code 42 - Electronic Spark timing.
    Honestly? I'm not to sure what that entails.
    But I'm guessing you could have a bad connection or a faulty item with the DFI module, coil packs.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yeah normally Fauly DFI module or Coil packs, sometimes both if your real lucky lol.
    Best thing would be upgrade to a series II DFI Module and Coil pack as its quite common for the Series I to fail.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    hi, thx alot guys, just bought a second habd coil pack and DFI module and it appears to be running fine. I let it idle for a while in drive a few times, rove it really hard then really nice etc and it didn't stall, :
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Hope it's fixed mate. I know what it's like. It's a PAIN in the back-side
  1. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  2. vn code 35
    By qik18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2008, 10:16 PM
  3. code 85
    By emo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 11:10 AM
  4. Code 76
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 10:52 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
