Results 1 to 13 of 13
Thread: Water Leak...
    VP Exec
    Mar 2009
    Melbourne, bayswater
    Default Water Leak...
    Hi Guys/Gals
    I was driving my car out of the drive way about 2 days ago and when i looked back there was a line of water on the ground.
    The strange thing is, when i start the car and let it idle its fine, but when i put it into drive and take off it will start leaking.
    I have gave it a really quick look at but couldnt see nothing, some of the hoses are really crap and i will replace them sometime this week.
    Has anyone had this problem before or herd of something like this?
    Please give me your thoughts, Thanks.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you had the aircon on it was probably water from the drain tube.
    MY RIDE
    VP Exec
    Mar 2009
    VR II V6
    May 2008
    I had a similar problem before and it took me months to figure it out.
    It was a faulty radiator cap. Its safety valve opened too soon letting hot coolant into the plastic tank which then overflowed via a hose that runs through the chassis so it cannot be seen from under the bonnet. The trouble is that the cap played up a lot, so it was good most of times.
    VP Exec
    Mar 2009
    i was just outside now, i let the car idle for around 15 mins. I did not see 1 leake.
    Took it up the street and there was a long line of water. WHAT THE HELL!
    I took a look at the water pump and it looked abit wet underneath.
    Oh and this is a serious 1 i think. i dont have a radiator cap. there is a tube running from the side of the radiator into the resivor bottle.
    So do you guys think that i might be the water pump?
    VR II V6
    May 2008
    Yes, it looks like it. Run a finger under it, just behind its pulley after you stop the engine (careful, don't get burned). If the finger is wet it is definetely the pump. It's got a hole in the body just behind its seal for early detection of seal failure. You should also be able to see coolant on the harmonic ballancer below the pump.
    Must have gone in a big way, though. Usually it only drips. Such a big leak you described is usually associated with hose rupture or reservoir overflow.
    Good luck. A new pump would cost about $75 - $80, plus labour if you can't do it yourself (it's not too hard).
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    VP Executive R-spec
    Jan 2005
    Are you 100% sure it's not water running out of the exhaust ??? there's TONS of water in the air you know and that doesn't burn and when your exhaust is cold it will all collect in the pipes then run out the back. I don't know where you live but if it's along the coast that should be what you are seeing
    VP Exec
    Mar 2009
    Thanks for the info guys.
    Im going over the car again today, i will check out the water pump which i think it might be.
    mar06mir there is no coolent on the harmonic ballancer.
    As i said before some of the hoses are in really bad condition, they are very stail and on the verge of cracking.
    I am going to replace them today and then see how it goes. If it still leaks then ill take off the water pump and see if thats the culprit.
    VZ EQUIPE
    Oct 2008
    Get the car, pressure tested. That way you will be able to tell exactly where the leak is and get it fixed.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You should be able to tell from the water on the ground whether it is from the cooling system or not, unless you have clean water in the radiator.
    MY RIDE
    VN exec S1
    Mar 2009
    The other day i took off from the lights next to a mate and gave it a fair bit. about a minute later the car started to get really hot and there was a big line of water on the ground. Turned out the hose that comes out of the left side of the water pump and runs under the steering pump had worked its self loose and slid out a little bit. I just pushed it back in and tightened the nut on the bracket and haven't seen a drop since. could be a possibilty.
    VP Exec
    Mar 2009
    I just came back from Bersons. I got some new hoses, ill put them on when it stops raining. im corssing my fingers that its just the hoses
  1. Oh no,Water leak
    By jonny6guns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2008, 10:39 PM
  2. Water Leak
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2008, 11:07 AM
  3. water leak
    By andyman in forum The Pub
    Last Post: 21-08-2006, 04:36 PM
  4. Water leak
    By Emu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2005, 12:24 AM
  5. VN water leak
    By NORTI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2004, 12:03 AM
