Results 1 to 10 of 10
Thread: loose dash?
    Vp commodore 3.8ltr v6
    Feb 2009
    Default loose dash?
    hey guys, jus wondering, i picked my car up on friday night and the dash is loose, i have tryed to tighten up the two screws underneath on both sides, (its the part right behing the steering wheel) not to sure what else i can do without whipping out the glue gun, any chance you guys could enlighten me?
    cheers
    lachlan
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    go to ur nearest holden an pick em up - i re did mine the other day they were 76cents each for the 2 plastic screw things
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The "dash" is loose? Really? What part lol
    The 1972 HQ Kingswood
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If the dash is loose you might have a serious problem. Apparently, when VN's were put together, the dash was 'fused' into the bodywork and became an integral part of the structure. If the dash is loose - as you claim - it's possible that the front end of your car could seperate. Get it checked by a good mechanic.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by Benboy View Post
    lol i think he just means the surround for his gauges where the hazard lights and wiper controls sit on.
    Go down to a wreakers (which are made of VN-VP commodores) and look for some sturdy dash boards and take the screws that fit them and it should be fine.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    May 2006
    Perth, Western Aust
    the bit under the dash the fuse cover panel is held on by 2 plastic screws - about 76cents each
    the bit above the steering wheel the dash cluster bit is held on by 4 mushroom head screws - can get them almost anywhere - either do em up if they are there are buy some new ones and do em up
    Morton's Avatar
    May 2006
    lmao, golden reply mate ^_^
    VN commodore S1 & VXII Berlina LS1
    Jan 2009
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    The old loose dash cluster surround as a result of sticky a fuel gauge and a slap happy previous owner story eh? You'd be surprised what you can fix with speed-nuts and a few screws...
    Feb 2009
    yeah, i just went and got some longer screws, sturdy as now. sorry for such a dumb post
LinkBacks (?)
  1. Will i loose power?
    By kurt in forum V6 Development And Modification
    Last Post: 25-02-2008, 04:46 PM
  2. very loose front end????
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2006, 01:18 PM
  3. Commodore on the loose!!
    By initial_3 in forum General
    Last Post: 15-11-2006, 03:35 PM
  4. loose wire
    By toughvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2005, 11:21 AM
